trigger 12V relay with 6V?
Lubrano
Copper - Posts: 113
Posted: July 31, 2017 at 9:25 PM / IP Logged Link to Post Post Reply Quote Lubrano
Working on a project for an older 6 volt vehicle. Is there a way to trigger the coil of 12 volt automobile relays with 6 volts?
Ween
Platinum - Posts: 1,366
Posted: August 01, 2017 at 6:47 PM / IP Logged Link to Post Post Reply Quote Ween
What are you trying to turn on with the relay? A small dc/dc converter adjusted to 12 volts or so out. Output side connected to the relay coil. Input would be controlled by a switch? More info would help.
Platinum - Posts: 13,670
Posted: August 05, 2017 at 7:22 PM / IP Logged Link to Post Post Reply Quote i am an idiot
You can easily use a resistor and a 5 volt relay. Find a 5 volt relay that will suit your needs and measure the resistance of the coil, let me know that reading. Also get me an actual voltage reading that will be triggering the relay.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
