Time delay on relay
tlautens
Posted: October 11, 2017 at 9:28 PM / IP Logged Link to Post Post Reply Quote tlautens
I was wondering if there is a way to wire a relay to turn on after seeing a 12v D.C. Switched source? Basically I need the relay to turn on about 20 sec after seeing the 12v switch source.
Platinum - Posts: 13,670
Posted: October 13, 2017 at 1:36 PM / IP Logged Link to Post Post Reply Quote howie ll
Or use a DEI 528t
tlautens
Posted: October 13, 2017 at 5:18 PM / IP Logged Link to Post Post Reply Quote tlautens
Did the research the 528t turns on when it sees the switch voltage. I need a relay that will turn on after 15sec after seeing the switch voltage and only stay turned on for 5 sec.
Posted: October 13, 2017 at 8:01 PM / IP Logged Link to Post Post Reply Quote i am an idiot
In your original post you said nothing about only staying on for 5 seconds. The thing I posted will do what is specified in your original post. It will remain on as long as 12 volts is applied.
Posted: October 14, 2017 at 1:40 AM / IP Logged Link to Post Post Reply Quote howie ll
Use 2 X 528t in series and next time remember to tell us about staying on for 5 seconds, it might have helped.
tdbaker021
Copper - Posts: 98
Posted: October 15, 2017 at 2:23 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Try a PAC TR12
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
