2016 Jeep Wrangler 3x lock
ziggyb222
Silver - Posts: 593
Posted: October 27, 2017 at 6:41 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Installing a stand alone remote start in my daughters 2016 Jeep JK. The shroud around the column will not come off. There is a lip the goes under the steering wheel. I just did a 2015 two weeks ago for a customer and the came right off. Is there a way to get the cover off without removing the steering wheel?? Thanks!!!
loganemakf
Member - Posts: 33
Posted: October 28, 2017 at 8:49 AM / IP Logged Link to Post Post Reply Quote loganemakf
You’ve probably already tried this but... Turn the wheel all the way left then all the way right and look for screws behind the steering wheel (like some toyotas)?
beegbie
Copper - Posts: 341
Posted: October 28, 2017 at 5:49 PM / IP Logged Link to Post Post Reply Quote beegbie
If you want to take the shroud off, the wheel needs to come off on the 2016. It's not difficult. Or you can just make your connections in the harness coming down the steering column.
ziggyb222
Silver - Posts: 593
Posted: October 30, 2017 at 6:20 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Thank You!!!
shafferny
Copper - Posts: 240
Posted: November 05, 2017 at 2:50 PM / IP Logged Link to Post Post Reply Quote shafferny
Yep. The shroud changed from the 15's to 16's for no apparent reason. My wife and I own both a '15 and a '16 Wrangler. I had to pull the air bag and steering wheel to install the T-harness on her Jeep(the '16).
ziggyb222
Silver - Posts: 593
Posted: November 05, 2017 at 5:59 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Did the wheel pop right off or were you able to pry the shroud off through the steering wheel???
shafferny
Copper - Posts: 240
Posted: November 05, 2017 at 6:35 PM / IP Logged Link to Post Post Reply Quote shafferny
I had to use a puller.I don't think you could remove it without one. It was on there pretty good.
ziggyb222
Silver - Posts: 593
Posted: November 06, 2017 at 5:01 PM / IP Logged Link to Post Post Reply Quote ziggyb222
Okay!!!!! Thank you...
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
