2003 Crown victoria door locks
luism21
Member - Posts: 16
Posted: November 10, 2017 at 3:31 PM / IP Logged Link to Post Post Reply Quote luism21
I am working on a 2003 crown Victoria installed Clifford 5305 everything works just fine except that when the door lock switch is used it blows the fuse I thought I left an exposed wire causing it to short out and blow but went thru all wiring and it was all protected. long story short once I disconnected the lock wires coming from the relays it stopped blowing the fuse. now my question is how can I fix this problem? I reversed the output of the doorlocks bc it needed a positive output.
Platinum - Posts: 13,670
Posted: November 10, 2017 at 5:11 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Draw us a diagram of how you wired the relays and maybe we can help.
luism21
Member - Posts: 16
Posted: November 10, 2017 at 5:40 PM / IP Logged Link to Post Post Reply Quote luism21
this is what I followed. but I just diode isolated it and it works fine now. was that a good idea or will I have problems in the future?
2003 Crown victoria door locks - Last Post -- posted image.
Posted: November 11, 2017 at 12:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Just remove ground from 87a of both relays.
rs specialist
Copper - Posts: 175
Posted: November 16, 2017 at 4:54 PM / IP Logged Link to Post Post Reply Quote rs specialist
are you sure they are positive and not reverse polarity?
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
