2007 Saab 9-3 Remote Start?
Member - Posts: 41
Posted: November 22, 2017 at 11:49 AM / IP Logged Link to Post Post Reply Quote 7808
i have a 07 saab 9-3 with the fob /ignition in front of the shifter. these seem to have unusually complicated anti-theft systems. does anyone have any tips for installing a remote start? also i only have one fob. honestly i wouldnt mind even totally disabling the anti theft because its very expensive to replace parts if you loose the key and the steering lock is prone to failure i guess.
Posted: November 22, 2017 at 12:41 PM / IP Logged Link to Post Post Reply Quote howie ll
Disabling the theft is irrelevant you still need to bypass the factory immobiliser. I did it in a 9-5.
If you have a manual you will have to remove the locket which if discovered will cancel your insurance.
geepherder
Platinum - Posts: 3,668
Posted: December 13, 2017 at 10:57 AM / IP Logged Link to Post Post Reply Quote geepherder
https://www.docdroid.net/D2bFsw0/saab-9-3-remote-start.pdf
freqsounds
Copper - Posts: 289
Posted: November 18, 2020 at 9:11 AM / IP Logged Link to Post Post Reply Quote freqsounds
Here's a copy of the same doc on the12volt. The link above tried to get me to download plugins.
https://www.the12volt.com/installbay/file.asp?ID=1470
No question is stupid or not worth asking. You were once a noob, right? :)
iskidoo
Silver - Posts: 1,040
Posted: November 18, 2020 at 4:24 PM / IP Logged Link to Post Post Reply Quote iskidoo
