Toyota oem chirp for arm/disarm
jonb2
Copper - Posts: 59
Posted: November 30, 2017 at 1:07 PM / IP Logged Link to Post Post Reply Quote jonb2
Hi all--found this question unanswered on an earlier post. On Toyota, Lexus, etc... w/ factory keyless entry soft chirp, can this be utilized to chirp when you arm/disarm with the alarm remote rather than using the alarm siren?
I would like to keep the soft chirp that the OEM vehicles have for when you lock/unlock but at the same time still retain the Viper siren when the alarm goes off.
thanks for any thoughts if this is possible!
bat9905
Copper - Posts: 131
Posted: December 21, 2017 at 10:39 PM / IP Logged Link to Post Post Reply Quote bat9905
What model vehicle and year? Do you know what bypass module is used?
bat9905
jonb2
Copper - Posts: 59
Posted: December 22, 2017 at 10:42 AM / IP Logged Link to Post Post Reply Quote jonb2
Vehicle is a 2007 Toyota 4runner. We used DEI XK05 bypass. thanks.
bat9905
Copper - Posts: 131
Posted: December 22, 2017 at 4:08 PM / IP Logged Link to Post Post Reply Quote bat9905
I know with newer Toyota vehicles you can retain factory beep. Idatalink doesn't show it as being offered so dei is probably the same. Looks like all that's is required is transponder bypass so data mode isn't even an option. Usually when this can be done it also allows user to arm and disarm aftermarket alarm with factory remotes.
bat9905
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
