avital 5105l
fastfrs1
Member - Posts: 9
Posted: December 02, 2017 at 6:25 PM / IP Logged Link to Post Post Reply Quote fastfrs1
i have a avital 5105l and trying to figure out why when the alarm goes off and i unlock the truck and turn the key on it doesnt reset the alarm can someone give me any info maby i missed hooking up a wire
Posted: December 02, 2017 at 7:04 PM / IP Logged Link to Post Post Reply Quote howie ll
Do you think you could tell us make model and year, then what you've wired to where orthewrwise no one is going to answer you because where does one start?
fastfrs1
Member - Posts: 9
Posted: December 02, 2017 at 7:25 PM / IP Logged Link to Post Post Reply Quote fastfrs1
its a 1994 chevy c 1500. so far all i have hooked up is door locks, siren, and park lights.
Posted: December 02, 2017 at 7:28 PM / IP Logged Link to Post Post Reply Quote howie ll
Try hooking up ignition and if this a remote start program safe start, also look in the vehicle wiring in case your vehicle is there.
fastfrs1
Member - Posts: 9
Posted: December 03, 2017 at 12:37 AM / IP Logged Link to Post Post Reply Quote fastfrs1
ok will do that will i need relays or no?
Posted: December 03, 2017 at 4:58 AM / IP Logged Link to Post Post Reply Quote howie ll
The wire on your ignition switch that goes to 12V+ on IGN (panel lights on) and stays live during cranking, connect to the PINK heavy gauge wire from the 5105.
Posted: December 03, 2017 at 4:59 AM / IP Logged Link to Post Post Reply Quote howie ll
You really should wire up the heavy gauge wires etc. etc. before asking these questions also when you join, solder.
fastfrs1
Member - Posts: 9
Posted: December 04, 2017 at 6:36 PM / IP Logged Link to Post Post Reply Quote fastfrs1
will i need relays to do so?
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
