2007 Nissan Altima, Avital 4103, dball2
ricardoboston
Copper - Posts: 268
Posted: December 31, 2017 at 9:07 AM / IP Logged Link to Post Post Reply Quote ricardoboston
hi there HAPPY NEW YEAR for you all , well I will start this post with one kind of problem that I have ever seen before ,I did an install on 2007 Nissan Altima hybrid   have used avital 4103 and dball2   everything works just fine only problem I have its when the remote start its running the radio and the console flash on and off for the entire remote start run time ,but if you turn off the remote start and turn on the car normally the problem will gone and everything comes to normal   I really appreciate. some help on this problem please thanks2007 Nissan Altima, Avital 4103, dball2 -- posted image. 2007 Nissan Altima, Avital 4103, dball2 -- posted image. 2007 Nissan Altima, Avital 4103, dball2 -- posted image.
geepherder
Platinum - Posts: 3,668
Posted: December 31, 2017 at 1:52 PM / IP Logged Link to Post Post Reply Quote geepherder
If you turn your key on without killing the remote start does your radio/console work properly?
It sounds like you have another wire to connect. Bulldog lists two ignition wires (one positive, one negative) and two accessory wires (both positive). http://diagrams.marktoonen.nl/printlist.aspx?MakeID=5&ModelID=19916
Are these all connected?
ricardoboston
Copper - Posts: 268
Posted: December 31, 2017 at 6:47 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hi geepherder this car its a push to start not sure if it still need thoses wires I try to upload the diagram but I can't ,if you please go to directechs you can see my install dball2 firmware NISS3HT type 1 thank you a lot for try to help me and happy new year for you and your family
geepherder
Posted: January 01, 2018 at 4:39 AM / IP Logged Link to Post Post Reply Quote geepherder
What you can do is test the wiring after you start with the smart key vs remote start. Use the bulldog wiring as a reference. If you notice one wire tests different during remote start than it does with the smart key, you might try hardwiring that output from the remote start.
ricardoboston
Copper - Posts: 268
Posted: January 01, 2018 at 6:22 AM / IP Logged Link to Post Post Reply Quote ricardoboston
I will try it soon as can and I will post the results thanks for your time very appreciated,HAPPY NEW YEAR
ricardoboston
Copper - Posts: 268
Posted: January 01, 2018 at 4:39 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hello my friend I have worked back on the car and no way to find out the problem the only thing is the brain of the avital 4105 clicks and clicks and the radio and the console keep flashing ,maybe its a fool question but a hook up the positive parking lights and the dball says it will do it D2D but on my first try it won't work so I hook up the positive parking lights ?
geepherder
Posted: January 01, 2018 at 4:58 PM / IP Logged Link to Post Post Reply Quote geepherder
I'm not sure what "there's no way to find out the problem" means. Did you test the wiring as listed? What were your results?
I can't offer much help with D2D, I've always hardwired. Maybe try to reset the module, and if that doesn't work reflash.
ricardoboston
Copper - Posts: 268
Posted: January 02, 2018 at 5:36 AM / IP Logged Link to Post Post Reply Quote ricardoboston
I meant the problem of this car its kind difficult but I think I will hardwire and see if works better thanks I let you know soon I got back to this car
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
