2018 Dodge Charger wiring diagram
Raymond4646
Copper - Posts: 121
Posted: January 31, 2018 at 11:38 PM / IP Logged Link to Post Post Reply Quote Raymond4646
Hey guys looking for a Remote Start/Security wiring diagram for a 18 charger pts V6
Thank you!
Twelvoltz
Platinum - Posts: 2,384
Posted: February 02, 2018 at 7:59 AM / IP Logged Link to Post Post Reply Quote Twelvoltz
I know this doesn't really answer your request, but...most of the data interfaces handle everything for you anymore. They have the ability to read the data-bus in the vehicle and provide you with a very simple interface.
If you take a look at Idata's ALCA they offer 2 different firmware options. One firmware will add remote start with just the data interface using the factory remote (hit lock 3x). The other firmware will give you pretty much everything else so that you can use an aftermarket alarm/starter without the need to interface the vehicle with each and every circuit.
Raymond4646
Copper - Posts: 121
Posted: February 02, 2018 at 1:04 PM / IP Logged Link to Post Post Reply Quote Raymond4646
Thanks for that info! I looked over the blade all install sheet and it was specific where the several wires I had to tag were. Times have changed for the better!
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
