2010 Honda Accord factory disarm wire
godd dan it
Copper - Posts: 446
Posted: February 01, 2018 at 9:22 PM / IP Logged Link to Post Post Reply Quote godd dan it
What color wire is the factory alarm disarm wire on a 2010 Honda Accord? Do I need to go into the driver’s side door?
Platinum - Posts: 7,783
Posted: February 02, 2018 at 5:02 AM / IP Logged Link to Post Post Reply Quote kreg357
What bypass module are you using?
With a vehicle like that, I look for a full featured bypass module that takes care of the
transponder and does the locks and alarm. Saves a bunch of time and doesn't cost much
more. My favorite module for that car is the ADS AL-CA flashed with the DL HA3 firmware.
A few connections at the ignition switch allows the bypass module to supply Tach, Brake,
Hood, Door & Trunk Status and take care of the locks and alarm without going into the door.
godd dan it
Copper - Posts: 446
Posted: February 02, 2018 at 3:02 PM / IP Logged Link to Post Post Reply Quote godd dan it
Yes I should have used a module that can do everything, but I was trying to save some money (a little more profit for me) on an install. I used the XK05 and completely forgot that it doesnt disarm the factory alarm. Now im paying for it in labor time.
geepherder
Platinum - Posts: 3,668
Posted: February 02, 2018 at 6:01 PM / IP Logged Link to Post Post Reply Quote geepherder
You should be able to do it at the power window master switch:
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=3&ModelID=20116
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=170220
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
