2002 Suburban Remote Start Wiring Issues
th3cavalry
Member - Posts: 6
Posted: February 12, 2018 at 9:36 PM / IP Logged Link to Post Post Reply Quote th3cavalry
Hello! I'm trying to install a R/S kit into a 02 Suburban.
I purchased a kit from eBay. https://www./itm/1999-2002-CHEVY-SILVERADO-ESCALADE-TAHOE-CAR-ALARM-REMOTE-STARTER-WITH-BYPASS/122600856612?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
It includes the GMDLBP and Automate AM7 alarm and R/S combo.
I've followed the wiring and done what I could but I cannot get the remote start to function or the door locks to work. I have the Bypass module and the AM7 door lock wirings hooked into the correct wiring but they don't work. I can hear the module clicking for the door lock and unlock and it doesnt do anything for pressing the remote start button.
It also seems like I can't get the bypass module programmed. I don't know how to test if it is.
Any help is appreciated! Thank you!
monty_77
Copper - Posts: 491
Posted: February 13, 2018 at 1:03 AM / IP Logged Link to Post Post Reply Quote monty_77
First off the gmdlbp is not for a 2002 it starts working on 2003s
Doing this might be easier on this truck
https://www.the12volt.com/addfile/files.asp?s=101306&f=Passloack%5FII%2Egif
Door locks are positive and located at bcc under steering wheel brown connector
Lock is lt blue a4
Unlock is white a3
https://www.the12volt.com/relays/relaydiagram1.html
th3cavalry
Member - Posts: 6
Posted: February 13, 2018 at 1:52 AM / IP Logged Link to Post Post Reply Quote th3cavalry
So when you say they are positive then a a 12v source is what triggers the unlock correct?
monty_77
Copper - Posts: 491
Posted: February 13, 2018 at 7:05 AM / IP Logged Link to Post Post Reply Quote monty_77
Yes you would have to wire in relays or something like dei 451m
Relays diagram
Bypass diagram
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
