Backup Camera, 2012 Ford E-450
icline
Posted: May 25, 2018 at 11:04 PM / IP Logged Link to Post Post Reply Quote icline
I am trying to put a backup camera in my work truck a 2012 ford e450 trying to find out what wire the reverse signal is on. Thanks
geepherder
Platinum - Posts: 3,668
Posted: May 26, 2018 at 4:54 AM / IP Logged Link to Post Post Reply Quote geepherder
Test the blue/white wire at the rear view mirror.
Platinum - Posts: 13,667
Posted: May 26, 2018 at 6:38 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If it is not at the mirror, that same wire is in the drivers kick panel in the harness going to the rear of the vehicle.
eguru
Copper - Posts: 340
Posted: May 26, 2018 at 7:37 PM / IP Logged Link to Post Post Reply Quote eguru
Autodimming rearview mirrors have reverse wired to the mirror so that the dimming is canceled when in reverse.
Posted: May 26, 2018 at 8:42 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Does your 1+ ton workhorse van have an auto dimming mirror? Let us know.
icline
Posted: May 26, 2018 at 11:51 PM / IP Logged Link to Post Post Reply Quote icline
No on the mirror and is it white with a blue stripe or the other way blue with a white stripe
Posted: May 27, 2018 at 8:24 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Blue with a white stripe. If you are having trouble finding it, it is also at the bulb in the back of the vehicle.
icline
Posted: May 29, 2018 at 8:47 AM / IP Logged Link to Post Post Reply Quote icline
No blue white wire checked at the light it has black red and yellow tried the yellow it does not activate the camera also tried to reverse the polarity no luck
geepherder
Posted: May 29, 2018 at 4:31 PM / IP Logged Link to Post Post Reply Quote geepherder
Do you have a multimeter? Do your reverse lights work?
Alternatively, you can test a brown/yellow wire (negative switched) at the transmission range sensor, PCM, or battery junction box. Of course, you'll need to invert the polarity with a relay.
eguru
Copper - Posts: 340
Posted: May 29, 2018 at 9:24 PM / IP Logged Link to Post Post Reply Quote eguru
Reversing the polarity may have damaged the unit.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
