Viper 5305v Locking Doors But Not Arming Alarm
ryaanriot
Posted: June 03, 2018 at 10:04 PM / IP Logged Link to Post Post Reply Quote ryaanriot
Hello everyone, lately I've been having a problem with my alarm not arming. Alarm is installed on a 94 Honda civic cx. Both the 2 way remote and the standard remote will only lock and unlock the doors and not arm the alarm at all. Then randomly after a few hours everything will work as normal. Its driving me crazy as I cannot figure out what is causing this. Any help would be greatly appreciated. Thank you
ryaanriot
Posted: June 04, 2018 at 3:58 AM / IP Logged Link to Post Post Reply Quote ryaanriot
Update: I got home from work and decided to mess around with it. If I change the Light Flash Polarity Jumper to the negative side the alarm will arm but the lights will not flash. And when I moved it back to the Positive side it would not arm again. Any reason for this? It was working fine up to this point, possibly a bad control module? or a short some where?
eguru
Copper - Posts: 340
Posted: June 04, 2018 at 7:29 AM / IP Logged Link to Post Post Reply Quote eguru
Is your dome light bulb burned out or have you changed to an LED type lately?
ryaanriot
Posted: June 04, 2018 at 1:09 PM / IP Logged Link to Post Post Reply Quote ryaanriot
Dome light is not burned out, and I am not using an LED. Still just the OEM bulb
davep.
Gold - Posts: 641
Posted: June 04, 2018 at 7:27 PM / IP Logged Link to Post Post Reply Quote davep.
Check the power connection you're using for the module. The fact that reversing the light flash polarity causes the system to react differently seems like a module power issue. If no problem found, try removing the fuse from the white light flash wire and see if it arms/disarms. If = yes it now works, the light circuit is drawing so much power the voltage in the module drops too far for it to function.
I think you have a bad or intermittent connection at the red power wire, or possibly at the black module ground connection.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
