2018 Toyota Highlander Window Control
tillithz
Member - Posts: 48
Posted: July 16, 2018 at 11:08 PM / IP Logged Link to Post Post Reply Quote tillithz
Has anyone done or know how to control, namely close, all 4 windows/sunroof on a 2018 Toyota Highlander w/ Push To Start?
All windows have a "one touch" or Auto feature and I have been told that the windows can not be controlled.
However, a DEI tech told me they have a wiring diagram describing how to do this. I am willing to get the 535T or any other device to control the windows with an aftermarket DEI alarm.
thanks in advance
beegbie
Copper - Posts: 341
Posted: July 21, 2018 at 7:34 PM / IP Logged Link to Post Post Reply Quote beegbie
You should test to see if the car can control the windows first. Roll the windows down then insert the key in the driver door key cylinder (car off. Turn it to lock, then back, then lock again and hold in the lock position. See if the windows close.
mgoetz74
Silver - Posts: 424
Posted: July 26, 2018 at 3:20 PM / IP Logged Link to Post Post Reply Quote mgoetz74
front left and right and sunroof are controlled by factory alarm, so a longer out put on the factory alarm arm wire will roll them up. The rears are in the drivers kick, grey 18 pin plug, left is yellow - white (without jam protection) and Right is lt. blue - lt. green (without jam protection). I personally don't like tapping into window stuff, not really my forte. Ive done a handful of the dei window timers and have had nothing but problems during and after the install with them.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
