What is the Wattage? Dual 6 Ohm VC Subs
xTimx
Copper - Posts: 354
Posted: July 24, 2018 at 12:27 AM / IP Logged Link to Post Post Reply Quote xTimx
WELL HEY THERE STRANGERS! i havent logged into the website for over 10yrs now haha. hope everyone is doing good here.
I still have some old school subs that are Dual Voice coil at 6ohms.   i have 2 of these subs.   Currently they are wired in Parallel/Parallel to get a 1.5ohm load on the amp (Bridged).
The AMP's ratings is as follows:
(4 Ω) (20 Hz – 200 Hz, 0.5 % THD) @ 200 W × 1
(4 Ω) (DIN : 45324 , +B = 14.4V) @ 200 W × 1
(2 Ω) (100 Hz, 0.5 % THD) @ 400 W × 1
(1 Ω) (100 Hz, 1.0 % THD) @ 500 W × 1
The amp can handle the load.
MY Q is..what wattage is the amp putting out? I'm trying to figure out a voltage to set the gains at here.
do i just meet in the middle and say its doing 450 Watts at 1.5ohms?
Thanks for all your help!
xTimx
the12volt
Administrator - Posts: 3,955
Posted: July 24, 2018 at 7:47 AM / IP Logged Link to Post Post Reply Quote the12volt
Those output ratings you listed are skewed to give you pretty round numbers, but are not realistic of what it will actually produce in your vehicle. Working from the 1 ohm rating listed at 500W, it would be 125W at 4 ohms and 250W at 2 ohms, so 333W at 1.5 ohms.
What amplifier are you using?
What is the Wattage? Dual 6 Ohm VC Subs - Last Post -- posted image. the12volt • Support the12volt.com
xTimx
Copper - Posts: 354
Posted: July 24, 2018 at 1:50 PM / IP Logged Link to Post Post Reply Quote xTimx
its an older amp Kenwood KAC-8101D
Link to the Manual
xTimx
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
