2006 Ford Freestyle, Steering Wheel Controls Wiring?
sabean
Member - Posts: 14
Posted: July 27, 2018 at 10:22 PM / IP Logged Link to Post Post Reply Quote sabean
I have a 2006 ford free style limited and the steering wheel controls don't work. they wont do anything on the menu screen I cant even reset the oli life but the audio controls work. does any one have a wiring schematic for the steering wheel controls.
Paul hoffman
wirewise
Moderator - Posts: 489
Posted: July 27, 2018 at 10:46 PM / IP Logged Link to Post Post Reply Quote wirewise
Try here: http://www.bbbind.com/tsb-wiring-diagrams/
~wirewise~ Verify all wiring with your meter before making any connections!
eguru
Copper - Posts: 340
Posted: July 28, 2018 at 7:28 AM / IP Logged Link to Post Post Reply Quote eguru
If the controls on one side of the wheel work, but not on the other side, then you may have a defective clockspring module.
This would not be unusual for a high mileage vehicle or if there has been a steering wheel airbag actuation.
sabean
Member - Posts: 14
Posted: July 30, 2018 at 2:16 AM / IP Logged Link to Post Post Reply Quote sabean
Yes that is what I thought to so I replaced the clock doing and nothing changed and I checked power in and out it’s good, and no shorts. Can you test those switches or take apart and clean contacts.
Paul hoffman
eguru
Copper - Posts: 340
Posted: July 30, 2018 at 10:17 AM / IP Logged Link to Post Post Reply Quote eguru
If you disconnect the clockspring, you can perform a resistance measurement across the 2 wires that are the steering wheel switches circuit.
It is a simple resistor network. Pressing any switch should change the resistance reading.
sabean
Member - Posts: 14
Posted: July 30, 2018 at 8:45 PM / IP Logged Link to Post Post Reply Quote sabean
well on the off chance that its not the switch any ideal on what it could be but I will try and ohm it out.
Paul hoffman
geepherder
Platinum - Posts: 3,668
Posted: July 31, 2018 at 7:45 AM / IP Logged Link to Post Post Reply Quote geepherder
Unplug/test at the light blue/red wire at the radio (pin 18):
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=123177
The values are listed at the bottom of the diagram, so with a little math you can figure out what each press should yield. If you can get a reading, but it's way off, you need to check the harness for any issues (retracted/dirty/corroded pins, poor contact pressure, pinched wire, etc.).
sabean
Member - Posts: 14
Posted: August 06, 2018 at 3:37 PM / IP Logged Link to Post Post Reply Quote sabean
Still need help I replaced the switch and test the wires and they all ohmed correctly so what other thing could I check is there away some could’ve turned it off in the computer
Paul hoffman
geepherder
Posted: August 06, 2018 at 6:32 PM / IP Logged Link to Post Post Reply Quote geepherder
I doubt it, but that may be a dealer question. You might pose the same question in a Freestyle forum.
You've verified the proper signal at the radio connector, so the problem could be inside the radio itself.
You could always go aftermarket and use an adapter to retain the steering wheel controls.
eguru
Copper - Posts: 340
Posted: August 07, 2018 at 8:36 AM / IP Logged Link to Post Post Reply Quote eguru
OP stated that the SW audio controls work so there is no need to make measurements at the radio connector.
The non-audio (message center, cruise control, airbag trigger) functions are through separate clock spring circuits.
Any measurements you make must be made with a DVM and with the battery disconnected - you don't want to trigger the airbag.
Best take it to a dealer.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
