2018 Nissan NV200 Alarm Diagram
teddy812
Member - Posts: 21
Posted: September 21, 2018 at 1:21 PM / IP Logged Link to Post Post Reply Quote teddy812
Hi.Does anyone have a security diagram for 2018 Nissan nv200?
thank you for your time.
full throttle
Platinum - Posts: 13,672
Posted: September 23, 2018 at 9:06 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      green (40A)      +      ignition switch, white 6 pin plug, pin 3
Ground      (chassis ground)
Starter      yellow      +      ignition switch, white 6 pin plug, pin 2
Ignition      blue      +      ignition switch, white 6 pin plug, pin 1
Accessory      red      +      ignition switch, white 6 pin plug, pin 4
Second Accessory      violet      +      ignition switch, white 6 pin plug, pin 5
Keysense      brown      +      key switch, white 2 pin plug, pin 1
CAN Bus High      blue      data      data link connector, white 16 pin plug, pin 6
CAN Bus Low      pink      data      data link connector, white 16 pin plug, pin 14
CAN Bus High 2      blue      data      BCM behind instrument cluster, white 40 pin plug, pin 39
CAN Bus Low 2      pink      data      BCM behind instrument cluster, white 40 pin plug, pin 40
IMMO Data      brown      data      NATS Antenna Amp on ignition switch, white 4 pin plug, pin 4
IMMO Data 2      brown      data      BCM behind instrument cluster, white 40 pin plug, pin 25
IMMO Clock      green      data      NATS Antenna Amp on ignition switch, white 4 pin plug, pin 2
IMMO Clock 2      green      data      BCM behind instrument cluster, white 40 pin plug, pin 21
Security Light      green      -      BCM behind instrument cluster, white 40 pin plug, pin 23
Power Lock      gray      -      driver kick or BCM behind instrument cluster, white 15 pin plug, pin 5
Power Unlock      red      -      driver kick or BCM behind instrument cluster, white 15 pin plug, pin 6
Lock Motor      green      5 wire      driver kick or BCM behind instrument cluster, black 15 pin plug, pin 10
Driver Unlock Motor      white      5 wire      driver kick or BCM behind instrument cluster, black 15 pin plug, pin 4
Passenger Unlock Motor      yellow      5 wire      passenger kick or BCM behind instrument cluster, black 15 pin plug, pin 11
Factory Alarm Arm      lt. blue (driver door key lock)      -      BCM behind instrument cluster, white 40 pin plug, pin 8 --or-- driver kick
Factory Alarm Disarm      yellow (driver door key unlock)      double -      BCM behind instrument cluster, white 40 pin plug, pin 7 --or-- driver kick
Disarm No Unlock      (see factory alarm disarm)
Parking Lights      red      +      driver kick, white 4 pin plug, pin 3 or white 100 pin plug, pin 62
Hazards      orange      -      hazard switch or BCM behind instrument cluster, white 40 pin plug, pin 29
Turn Signal (Left)      yellow      +      driver kick or BCM behind instrument cluster, black 15 pin plug, pin 5
Turn Signal (Right)      green      +      passenger kick or BCM behind instrument cluster, black 15 pin plug, pin 6
Headlight      blue (L); violet (R)      +      headlights or underhood fuse box, brown 8 pin plug, pins 4, 6
Reverse Light      orange      +      driver kick, white 4 pin plug, pin 4 or white 100 pin plug, pin 63
Left Front Door Trigger      lt. blue      -      driver kick or BCM behind instrument cluster, white 15 pin plug, pin 7
Right Front Door Trigger      orange      -      passenger kick or BCM behind instrument cluster, white 40 pin plug, pin 12
Right Rear Door Trigger      orange (sliding door, left/right back door lower)      -      passenger kick or BCM behind instrument cluster, white 15 pin plug, pin 8
Dome Light      blue      -      driver A pillar or BCM behind instrument cluster, black 15 pin plug, pin 8
Trunk/Hatch Pin      gray (right back door upper)      -      driver A pillar or BCM behind instrument cluster, white 40 pin plug, pin 13
Trunk/Hatch Release      (locks/unlocks along with doors)
Tachometer      NOT white or white/green      ac      any fuel injector
Fuel Pump      red      +      underhood fuse box, white 16 pin plug, pin 11
Rear Defroster      brown      -      rear defogger switch or BCM behind instrument cluster, white 40 pin plug, pin 10
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      gray      5 wire      left front heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat      gray      5 wire      right front heated seat switch, brown 6 pin plug, pin 5
Speed Sense      pink (mid and premium audio only)      8-Pulse      radio, white 20 pin plug, pin 18
Brake Wire      lt. green      +      driver kick, white 4 pin plug, pin 2 or white 100 pin plug, pin 51
Parking Brake      green      -      parking brake switch, black 1 pin plug, pin 1
Horn Trigger      white      -      driver kick, white 16 pin plug, pin 14
Wipers      blue (LO); lt. blue (HI)      +      wiper motor or underhood fuse box, brown 12 pin plug, pins 8, 11
Left Front Window (Up/Down)      red - yellow      A      power window main switch, white 16 pin plug, pins 8 - 11
Right Front Window (Up/Down)      violet - green      A      driver kick, white 12 pin plug, pins 10 - 11
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
