Auto Lock - Hoping for Clarification
ewingr
Copper - Posts: 60
Posted: October 30, 2018 at 11:05 AM / IP Logged Link to Post Post Reply Quote ewingr
Not being educated in electronic diagrams, I am hoping to verify or get direction on wiring up a diagram to set up autoloc in my car.
Below is the diagram for autolock from this site:
Auto Lock - Hoping for Clarification - Last Post -- posted image.
I understand the diagram, EXCEPT for the capacitor and resistor hookup. Below is a crude representation of how I interpret it:
Is the above diagram correct?
Next, my presumption is that it would output a constant negative when the door is closed and the ign is on. I need a momentary negative. So I found this:
I am assuming that the switched negative from above would feed to the negative output to lock circuit on the previous diagram. Correct?
I presume that if my first interpretation of how the resistor and capacitor wire up it would be the same for the above diagram. I also presume that I would need to capacitor and resistor for BOTH relays. Would that be correct?
And finally, I would like to verify that this capacitor and this resistor would meet my needs.
Sorry for the several embedded questions, but I though the questions at the point of the problem description was better than all listed below.
I really appreciate your input and help.
Roger
Platinum - Posts: 13,672
Posted: October 30, 2018 at 3:02 PM / IP Logged Link to Post Post Reply Quote i am an idiot
All you need is the original circuit you posted. It is just a pulsed output. You do have the capacitor and resistor configured correctly. Your capacitor and resistor are perfect.
ewingr
Copper - Posts: 60
Posted: October 30, 2018 at 4:41 PM / IP Logged Link to Post Post Reply Quote ewingr
Thank you so much for your reply.
Roger
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
