2010 Subaru Forester Remote Start
robtotoreb
Posted: December 04, 2018 at 11:08 AM / IP Logged Link to Post Post Reply Quote robtotoreb
Hello everyone,
I am looking to for a wiring diagram for a remote start application for a 2010 Subaru Forester 2.5X Premium.
I found the remote start wiring for a 2010 Outback but not sure if that is consistent with the Forester.
Equipment I'm looking at:
Avital 4105L Avistart Remote Start
Universal Immobilizer Bypass for Remote Start
I'm hoping this equipment allows me to use the existing stock security system but with the advantage of added remote start. I have a single chipped key that I plan to permanently place in the immobilizer box, and have 2 other non-chipped keys to use on the daily.
Thanks in advance!
-Rob
geepherder
Platinum - Posts: 3,668
Posted: December 04, 2018 at 11:52 AM / IP Logged Link to Post Post Reply Quote geepherder
Bulldog and Modified Life both have it listed:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=39&ModelID=20037
Modified Life (dot com)
ahartung
Posted: December 06, 2018 at 5:07 PM / IP Logged Link to Post Post Reply Quote ahartung
I've got a '10 Forester too and want to hook my remote start so the rear defrost works, however I am having a hard time locating the wire. Does anyone know the location of it? It was not listed in either of the two wire diagrams above.
geepherder
Posted: December 06, 2018 at 8:10 PM / IP Logged Link to Post Post Reply Quote geepherder
Check here:
http://www.bbbind.com/free-tsb
ahartung
Posted: December 06, 2018 at 8:36 PM / IP Logged Link to Post Post Reply Quote ahartung
I need to know where to find the actual wire in the vehicle. If that diagram shows it, I am too ignorant to figure it out.
I don't know where the Body Integrated Unit is. Do I need a harness plug that looks like i84 at wire 16? What does BrL stand for? The color of the wire?
Thank you.
ahartung
Posted: December 06, 2018 at 8:57 PM / IP Logged Link to Post Post Reply Quote ahartung
Did some research and figured out the wire color code, but still need to find the BIU.
geepherder
Posted: December 06, 2018 at 11:07 PM / IP Logged Link to Post Post Reply Quote geepherder
Bulldog says it's under the driver's dash, right of the steering column.
tonanzith
Gold - Posts: 593
Posted: December 08, 2018 at 9:52 PM / IP Logged Link to Post Post Reply Quote tonanzith
2010 Subaru Forester - North America
        Item Wire Color Polarity Wire Location
          12 Volts white (50A) + ignition switch, white 6 pin plug, pin 3
          Ground (chassis ground)
          Starter white/black + ignition switch, white 6 pin plug, pin 2
          Second Starter white/red + ignition switch, white 6 pin plug, pin 6
          Ignition green + ignition switch, white 6 pin plug, pin 1
          Accessory blue + ignition switch, white 6 pin plug, pin 4
          Second Accessory yellow + ignition switch, white 6 pin plug, pin 5
          Keysense black/white + BIU right of steering column, white 30 pin plug, pin 2
          CAN Bus High red (high-speed CAN) data BIU right of steering column, white 26 pin plug, pin 3
          CAN Bus Low blue (high-speed CAN) data BIU right of steering column, white 26 pin plug, pin 9
          CAN Bus High 2 pink (low-speed CAN) data BIU right of steering column, white 35 pin plug, pin 1
        CAN Bus Low 2 blue (low-speed CAN) data BIU right of steering column, white 35 pin plug, pin 9
        IMMO Data white/blue (1); black/red (2) data
BIU right of steering column, white 26 pin plug, pins 4, 15
          Security Light brown/red - BIU right of steering column, white 35 pin plug, pin 10
          Keyless Data gray/red data BIU right of steering column, white 35 pin plug, pin 24
          Power Lock lt. green - BIU right of steering column, white 35 pin plug, pin 15
          Power Unlock blue/black - BIU right of steering column, white 35 pin plug, pin 29
          Lock Motor lt. green/yellow 5 wire BIU right of steering column, white 35 pin plug, pin 7
        Driver Unlock Motor yellow/black 5 wire BIU right of steering column, white 35 pin plug, pin 23
        Passenger Unlock Motor
red/green 5 wire
BIU right of steering column, white 35 pin plug, pin 8
          Factory Alarm Arm arms on lock with driver door open
          Factory Alarm Disarm see disarm no unlock
          Disarm No Unlock transponder, ignition, and keysense
          Parking Lights pink + dash fuse box, white 20 pin plug, pin 12
          Parking Lights - black/white - BIU right of steering column, white 26 pin plug, pin 11
          Hazards green - BIU right of steering column, white 28 pin plug, pin 22
          Turn Signal (Left) lt. green + dash fuse box, white 20 pin plug, pin 20
          Turn Signal (Right) blue/black + dash fuse box, white 20 pin plug, pin 3
          Headlight blue/black - BIU right of steering column, white 28 pin plug, pin 8
          Reverse Light brown/yellow + passenger kick, harness to rear
          Left Front Door Trigger orange/white - BIU right of steering column, white 35 pin plug, pin 19
          Right Front Door Trigger blue/orange - BIU right of strng column, wht 35 pin plug, pin 32
          Left Rear Door Trigger yellow/red - BIU right of strng column, wht 35 pin plug, pin 20
        Right Rear Door Trigger white/red - BIU right of strng column, wht 35 pin plug, pin 6
        Dome Light blk/rd (dome/puddle lght), blk/blu (spot - BIU right of steering column, white 30 pin plug, pins 5, map lght) 4
          Trunk/Hatch Pin white - BIU right of steering column, white 35 pin plug, pin 33
          Hood Pin yellow/black - hood switch, white 2 pin plug, pin 1
          Trunk/Hatch Release green/red (rear handle switch) - BIU right of steering column, white 28 pin plug, pin 24
        Trunk Release Motor green/orange 5 wire BIU right of steering column, white 35 pin plug, pin 22
        Tachometer gray/red ac
instrument cluster, white 40 pin plug, pin 32
       Note - Tachometer: Also found at the Engine Control Module below glove box, 35 pin plug (C), pin 22.
       Neutral Safety green/black (M/T) - (C), pin 31
          Clutch Pedal blue/white + clutch switch, white 2 pin plug, pin 2
          Fuel Pump red/black + passenger kick, harness to rear
          Rear Defroster brown/blue - BIU right of steering column, white 35 pin plug, pin 16
          Mirror Defroster same as rear defroster
          Speed Sense pink/green ac instrument cluster, white 40 pin plug, pin 31
          Brake Wire lt. green + BIU right of steering column, white 26 pin plug, pin 2
          Parking Brake gray - BIU right of steering column, white 28 pin plug, pin 15
        Horn Trigger red/white - BIU right of steering column, white 30 pin plug, pin 29
        Wipers red/blue (L), black/blue (H), yellow/black + wiper switch, white 18 pin plug, pins 7, 8, and 17 (ignit)
          Left Front Window blue/red - blue/green A power window main switch, white 16 pin plug, pins 16 (Up/Down) and 13
          Right Front Window (Up/Down)
red to brown/red - red/yellow A driver kick, white 28 pin plug, pins 5 and 6
          Left Rear Window (Up/Down)
green/red - black/yellow A driver kick, white 28 pin plug, pins 9 and 10
          Right Rear Window (Up/Down)
blue - blue/yellow to red/black A driver kick, white 28 pin plug, pins 7 and 8
          Sun Roof (Open/Close) black/yellow - white (function with ignit on - sunroof switch, white 5 pin plug, pins 1 and 4 only)
          Radio 12V blue/red + radio, white 20 pin plug, pin 20
          Radio Ground black - radio, white 20 pin plug, pin 10
          Radio Ignition yellow/red + radio, white 20 pin plug, pin 3
          Radio Illumination violet (parking lights), black/white (dimmer) +,- radio, white 20 pin plug, pins 1 and 2
          Power Antenna yellow/black + radio, white 20 pin plug, pin 9
          Left Front Speaker (+/-) brown/white - brown +,- radio, white 20 pin plug, pins 7 and 8
          Right Front Speaker (+/-) blue/yellow - blue/white +,- radio, white 20 pin plug, pins 17 and 18
          Left Rear Speaker (+/-) red/yellow - white/black +,- radio, white 20 pin plug, pins 5 and 6
          Right Rear Speaker (+/-) gray/red - gray +,- radio, white 20 pin plug, pins 15 and 16
          Aux. Audio Input Left (+/-) white + radio, white 8 pin plug, pin 1
        Aux. Audio Input Right (+/-) red + radio, white 8 pin plug, pin 2
    What Fits?
    Item
Size
     Depth
Location
Headunit
double DIN
      center of dash
Gary Sather
ahartung
Posted: December 09, 2018 at 4:29 PM / IP Logged Link to Post Post Reply Quote ahartung
Great info, thank you. Found the correct wire and tested it, just have to finish the rest of the install.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
