08 Sienna XLE, Can Power Sliding Doors Work While R/S
Nuffstylez
Copper - Posts: 58
Posted: December 04, 2018 at 9:03 PM / IP Logged Link to Post Post Reply Quote Nuffstylez
Hi, just got an 08 Sienna XLE. Looking to install a remote start system but need a little guidance. Which alarm and bypass will let me operate the sliding doors while the car is being remote started. I know Toyota kills the factory keyfob while the car is started. Did some research and couldn't get an definite answer. Thanks in advance.
geepherder
Platinum - Posts: 3,668
Posted: December 04, 2018 at 11:38 PM / IP Logged Link to Post Post Reply Quote geepherder
If the switches in the car work while it's running, you should be able to do this using auxiliary outputs (as long as your remote start has them). Say you use Aux1 for the left door, and Aux2 for the right door. Activating Aux1 would cause a relay to energize momentarily. Terminal 87 would connect to one of the wires on the applicable switch, and terminal 30 would be connected to the wire on the other side of the switch.
Bookmark this page:
http://www.bbbind.com/free-tsb
Select wiring diagrams, vehicle, body & accessories, power sliding doors:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=163362
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
