Should I Wire My Amp and Sub at 1 Ohm or 4 Ohms?
Welcome Guest :)
treycherry16
Member -
Posted: December 09, 2018 at 10:28 AM / IP Logged
I have a 1500 watt sub dvc 2 and a 4000 watt amp. The amp is rated 3000 watts and 1 ohm and at 4 ohms it’s rated 750 watts. I have 0 awg wiring and I was wondering if it would be better to wire at 1 or 4 ohm.
tonanzith
Gold -
Posted: December 09, 2018 at 10:35 AM / IP Logged
Wire 1 ohm and keep the gain down on the amp. Use a meter to set the amp appropriately so as not to blow the sub.
Gary Sather
treycherry16
Member -
Posted: December 09, 2018 at 1:53 PM / IP Logged
When you say use a meter, what exactly is that and how do I use it.
tonanzith
Gold -
Posted: December 09, 2018 at 2:21 PM / IP Logged
Oh boy. Use a multimeter to meter the volts out of the amp. Use ohms law to determine how many watts that is delivering to the sub. By doing this you can set the gain so when you turn the volume up you don’t blow your sub....
Gary Sather
Platinum -
Posted: December 09, 2018 at 6:29 PM / IP Logged
What is the RMS power handling of the sub?
tonanzith
Gold -
Posted: December 09, 2018 at 8:03 PM / IP Logged
Said “1500” watt. But, guess I should have asked if he knew if it was rms or China peak power. Lol
Gary Sather
treycherry16
Member -
Posted: December 09, 2018 at 9:24 PM / IP Logged
The rms is 1500. It’s a 3000 watt peak. Skar vxf 12 d2
treycherry16
Member -
Platinum -
Posted: December 10, 2018 at 2:14 PM / IP Logged
What is the Brand and the model of your amplifier?
treycherry16
Member -
Posted: December 10, 2018 at 6:10 PM / IP Logged
It is a sound storm mono block ev4000d
Sunday, March 1, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
