08 Avalon Push to Start
jhughley
Member - Posts: 12
Posted: January 03, 2019 at 7:14 AM / IP Logged Link to Post Post Reply Quote jhughley
Does anyone have a picture of the location or can tell me the location of the Ignition Switch. I can't seem to locate it.
Thanks,
Jason
Jason
geepherder
Platinum - Posts: 3,668
Posted: January 03, 2019 at 7:25 AM / IP Logged Link to Post Post Reply Quote geepherder
It's the start stop button just to the left of the radio.
jhughley
Member - Posts: 12
Posted: January 03, 2019 at 7:48 AM / IP Logged Link to Post Post Reply Quote jhughley
Does the following only apply to a Keyed ignition then? I've completed one other Pust to start remote starter and I seem to recall that it still had a larger wire harness coming out of the side with these connections.
2 VOLT CONSTANT     BLACK (+)     @ IGNITION SWITCH HARNESS
STARTER     BLUE (+) See NOTE #5     @ IGNITION SWITCH HARNESS
STARTER 2     RED (+) See NOTE #5     @ IGNITION SWITCH HARNESS
IGNITION 1     YELLOW (+)     @ IGNITION SWITCH HARNESS
IGNITION 2     GREEN (+)     @ IGNITION SWITCH HARNESS
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     GRAY (+)     @ IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2     N/A
KEYSENSE     BLACK (-)     @ IGNITION SWITCH HARNE
Thanks,
Jason
Jason
geepherder
Posted: January 03, 2019 at 9:59 AM / IP Logged Link to Post Post Reply Quote geepherder
According to Bulldog, the connections are made at the interface, not the ignition harness. See here:
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=2&ModelID=20130
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
