building a box
bigmurf127
Member - Posts: 25
Posted: June 05, 2003 at 10:13 PM / IP Logged
just started building a sub box for my dakota and i was wondering what is the most accurate tool for cutting out the holes for the subs.  I was thinking jig saw but what do you guys use.  Also where can i get some cheap box carpet
Sound Pressure
Silver - Posts: 711
Posted: June 05, 2003 at 10:26 PM / IP Logged
I use a router and a circle cutting jig. The jig runs about $30 but you can build your own out of wood to save you money. I bought my router at sears and the jig at lowes home improvement. That has been the most acurate for me. You can also use the dremel that comes with a circle cutting jig that I believe can cut up to a 12" radius. As far as "cheap" box carpet you can find that at either autozone or walmart. Use 3m spraying glue which I find works best for bonding real good.
Sound Pressure
bigmurf127
Member - Posts: 25
Posted: June 06, 2003 at 1:48 PM / IP Logged
well i work at sears so i can get tools cheap, just didn't know which one to buy, i was thinking of using a spiral saw, like a rotozip.
IronCy
Copper - Posts: 93
Posted: June 06, 2003 at 2:23 PM / IP Logged
Rotozips are pretty good, but the standard circle jig for the roto zip will not do a 15" woofer.  As long as you are building a box for 10's or 12's you should be fine.  I think that they do have a circle jig for the rotozip that will extend to 24"  I think that routers and circle jigs are more commonly used when the circle has to be perfect---fiberglassing, but a steady hand and a good ole jig saw is fine it is just a plain ole box.
Hope this helps,
-Cy
speedwayaudio1
Silver - Posts: 879
Posted: June 06, 2003 at 2:25 PM / IP Logged
the rottozip works well and it comes with the hole jig. it only gos up to 14" so if you have 15's you have to free hand. but the rottozip its easy to free hand. carpet go to autozone.
Big Dave
thepencil
Gold - Posts: 1,526
Posted: June 06, 2003 at 2:36 PM / IP Logged
I use a jigsaw. As for the blade, get the best blade that you afford a good blade will give you a better looking circle. For the port you can use a hole saw. Try your local carpet store, they might have what you need or direct to one.
Be careful whose advice you buy, but be patient with those who supply it.building a box -- posted image.
esmith69
Gold - Posts: 1,511
Posted: June 06, 2003 at 5:14 PM / IP Logged
Best Buy sells grey subwoofer carpeting, but on the packaging it's called "trunk liner" or something like that.  I think it's like 10 bucks for enough to do a 12" box but I don't remember the dimensions exactly.
Ethan
Donate to the12volt.com
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
