Wiring 3 Ohm Speakers to 2-4 Ohm Rockville Amp
hemi10
Posted: May 16, 2019 at 9:03 PM / IP Logged Link to Post Post Reply Quote hemi10
Can anyone give some suggestions on wiring 2 jbl 6.5" 2.3ohm speakers and 2 jbl 6x9 3ohm speakers to a 2-4ohm 4 channel Rockville amp ? I also wanted to add 2 3.5" speakers in the dash to give the system more of a surround sound setup but I'm not sure that it will be possible, if so what ohm should I buy ? I read some information on wiring resistors in that change ohms but didn't fully understand. Also came across some more information in regards to using the head unit speaker outputs. So if anyone can help me with how to wire my setup I would appreciate it.
Hemi10
Platinum - Posts: 13,725
Posted: May 17, 2019 at 5:21 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Connect 1 speaker to each channel of the amplifier.
gshookupz
Member - Posts: 21
Posted: May 17, 2019 at 1:28 PM / IP Logged Link to Post Post Reply Quote gshookupz
there should be no issue at all.
Observe correct polarity and thats it. Maybe use the front left and right output of the deck on those threes up in the dash.
Or reconsider those threes and get some nice tweeters up there where the imaging is best. If your gonna use the threes, I would protect them by using a 200mfd non directional cap to block the lows off them. this is an old school 6db passive crossover.
Just install on positive line at the speaker.
hope this helps!
Do it movin! "I still have the Twindows modules from My 86 mr2 in the bottom of my box"
hemi10
Posted: May 17, 2019 at 1:37 PM / IP Logged Link to Post Post Reply Quote hemi10
Both good answers, doesn't sound so complicated as I was thinking. Tweeters in the dash, ok , should I purchase a pair that are the same ohms as the rest of my speakers ? And running off the head unit which is a Kenwood ddx795 and less power then the speakers that will be driven from my 4 channel amp will the tweeters or really any speakers installed in the dash be worth it as far as the difference they will make over not having them ? Thanks again !
Hemi10
Posted: May 17, 2019 at 7:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I missed the part about the dash speakers. You will need to install a capacitor in series with the 3.5 inch drivers. 100 volt non polarized. I will find the chart you need to determine the value of the capacitors. I will post it in a second.
Posted: May 17, 2019 at 7:09 PM / IP Logged Link to Post Post Reply Quote i am an idiot
hemi10
Posted: June 19, 2019 at 7:06 PM / IP Logged Link to Post Post Reply Quote hemi10
Thanks for your help !
Hemi10
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
