Starter Kill Relay, 1968 Chevrolet Chevelle
1978malibu
Member - Posts: 23
Posted: June 21, 2019 at 11:14 AM / IP Logged Link to Post Post Reply Quote 1978malibu
I have a 1968 chevelle, not sure if it's normally closed or normally open. Dont know which diagram to use.
catback
Silver - Posts: 703
Posted: June 21, 2019 at 11:29 AM / IP Logged Link to Post Post Reply Quote catback
Depends on your alarm:
If your alarm has a "when disarmed" output use the Normally Open diagram
If your alarm has a "when armed" output use the Normally Closed diagram
The normally open diagram is preferred if both are possible with your alarm as when someone tries to start the vehicle without disarming the alarm, the relay does not click and give away it's purpose and location behind/under the dash.
Platinum - Posts: 13,673
Posted: June 21, 2019 at 4:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Key side of start wire to 30 and 86. Ground out from alarm to 85. Starter side of start wire to 87A
1978malibu
Member - Posts: 23
Posted: June 22, 2019 at 12:04 PM / IP Logged Link to Post Post Reply Quote 1978malibu
Starter Kill Relay, 1968 Chevrolet Chevelle - Last Post -- posted image.
1978malibu
Member - Posts: 23
Posted: June 22, 2019 at 12:14 PM / IP Logged Link to Post Post Reply Quote 1978malibu
86 to key ing
85 to alarm output
87 to ing switch
30 to starter motor
Is this correct?
catback
Silver - Posts: 703
Posted: June 22, 2019 at 12:23 PM / IP Logged Link to Post Post Reply Quote catback
1978malibu wrote:
86 to key ing
85 to alarm output
87 to ing switch
30 to starter motor
Is this correct?
Yes 86 to ignition switch HOT in RUN and CRANK wire
85 to alarm ground while disarmed*
87 to ignition switch START wire - ignition side of cut
30 to ignition switch START wire - starter motor side of cut
* the alarm MUST output a constant ground on this wire while the system is disarmed. A pulsed factory disarm or door lock unlock signal WILL NOT work.
Posted: June 22, 2019 at 8:20 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What alarm has a ground when disarmed?
Malibu, what kind of alarm do you have?
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
