Headlight Wiring, 2004 Ford Expedition/Lincoln Navigator
tis4life
Posted: July 09, 2019 at 11:05 AM / IP Logged Link to Post Post Reply Quote tis4life
trying to fix headlights,,smh,,,, both are not working and after going threw all the abc,s i found the issue to be that the line that feeds the headlights is grounded. I need a copy of 2004 Ford Expedition Lincoln Navigator Wiring Diagram Manual to trace the wires to find the short
dlt
geepherder
Platinum - Posts: 3,668
Posted: July 10, 2019 at 5:58 PM / IP Logged Link to Post Post Reply Quote geepherder
You may be reading a ground through the bulbs. If you unplug the headlights, does the ground go away?
I'm not sure if this is the correct diagram, but it came up in a search and is listed for 2003:
Headlight Wiring, 2004 Ford Expedition/Lincoln Navigator - Last Post -- posted image.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
