Viper 211HV, Actuator Wiring with No Locks on 73 Trans Am
Ween
Platinum - Posts: 1,366
Posted: September 04, 2019 at 8:00 PM / IP Logged Link to Post Post Reply Quote Ween
Disconnect the unlock side of the passenger door actuator. Add a SPDT relay. Connections to the relay: Terminal 30 to Unlock side of passenger door actuator, Terminal 87A to Ground
(can use same ground as H1/6 & H1/17), Terminals 87 & 86 to Battery (can use same battery as H1/7 & H1/9), Terminal 85 to second unlock output (H1/2).
jlutz455
Member - Posts: 9
Posted: September 05, 2019 at 7:29 AM / IP Logged Link to Post Post Reply Quote jlutz455
Thanks guys for the input and help! I'll hook it up per Ween's suggestion. Looks pretty straightforward and let you know.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
