2005 Kia Sorento Radio Diagram?
tylerp420
Member - Posts: 6
Posted: August 28, 2019 at 3:24 PM / IP Logged Link to Post Post Reply Quote tylerp420
Anybody have a Radio Wiring Diagram for a 2005 Kia Sorento? I've been searching for hours and can't find one. Thanks for any help. I'm trying to install a XNAV267BT Aftermarket touchscreen radio.
motosaki
Member - Posts: 24
Posted: August 28, 2019 at 3:29 PM / IP Logged Link to Post Post Reply Quote motosaki
Radio 12V     green     +     radio, white 16 pin plug, pin 8 or black 24 pin plug, pin 13
Radio Ground     black     -     radio, white 16 pin plug, pin 16 or black 24 pin plug, pin 12
Radio Ignition     green/orange     +     radio, white 16 pin plug, pin 1 or black 24 pin plug, pin 14
Radio Illumination     red/black (parking lights); yellow (dimmer)     +,-     radio, white 16 pin plug, pins 9, 2 or black 24 pin plug, pins 16, 17
Factory Amp Turn-on     yellow/black     +     radio, black 24 pin plug, pin 18
Left Front Speaker (+/-)     black - brown or lt. green - blue     +,-     radio, white 16 pin plug, pins 14 - 5 or black 24 pin plug, pins 8 - 9
Right Front Speaker (+/-)     blue/orange - green/orange or brown/blk - green/rd     +,-     radio, white 16 pin plug, pins 11 - 4 or black 24 pin plug, pins 23 - 22
Left Rear Speaker (+/-)     blue - green or yellow/blue - yellow/green     +,-     radio, white 16 pin plug, pins 15 - 6 or black 24 pin plug, pins 20 - 21
Right Rear Speaker (+/-)     yellow - blue or red - yellow     +,-     radio, white 16 pin plug, pins 10 - 3 or black 24 pin plug, pins 11 - 10
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Platinum - Posts: 13,672
Posted: August 29, 2019 at 10:06 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Did you already hack the plug off the end of the cars harness? If not, don't.
tylerp420
Member - Posts: 6
Posted: August 29, 2019 at 10:22 AM / IP Logged Link to Post Post Reply Quote tylerp420
I haven't done anything yet, why? That's what I was going to do though, I was going to cut the old harness off and put the wires together to the XNAV267BT harness.
Posted: August 29, 2019 at 12:16 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Metra and plenty other manufacturers make a harness that plugs into that harness and has the same color wires as your new aftermarket radio. There are 2 possible harnesses for that vehicle.
http://www.metraonline.com/part/70-7301
http://www.metraonline.com/part/70-2003
tylerp420
Member - Posts: 6
Posted: August 29, 2019 at 12:22 PM / IP Logged Link to Post Post Reply Quote tylerp420
So I wouldn't have to cut the wires? I can just plug that into the old harness and connect those wires to the new radio and I just connect the same color of wires together?
tylerp420
Member - Posts: 6
tylerp420
Member - Posts: 6
Posted: August 29, 2019 at 5:16 PM / IP Logged Link to Post Post Reply Quote tylerp420
I ended up getting this one because the other one alone wouldn't ship to my PO Box. Will it work?
https://www.amazon.com/gp/aw/d/B0189NH9DA/ref=ya_aw_od_pi?ie=UTF8&psc=1
Posted: August 29, 2019 at 9:28 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Depending on which car you have. Obviously some of them were built using the GM harness. Some were built using the basic Hyundai/Kia harness. You should have removed the radio and see which harness your vehicle has.
tylerp420
Member - Posts: 6
Posted: August 29, 2019 at 11:00 PM / IP Logged Link to Post Post Reply Quote tylerp420
I'm pretty sure it's 24 pin, I already removed it and checked it out.
