Suggestions on My Prelude's System
timbo74
Posted: August 29, 2019 at 6:45 PM / IP Logged Link to Post Post Reply Quote timbo74
I am not exactly new to car audio, I have installed several systems, but would still like some advise, from the pros.
I currently have one Alpine type R 12” gen one, in a sealed enclosure running off an Alpine M500, and Boston Rally series 6.5 coax in the doors, running off the head unit.
I bought a set of Boston SL60 components for my Prelude, But I have been seriously contemplating going a different route with my summer car. I may put the Boston’s in the winter beater, and go with pro series drivers, using the head units crossover, and bridge the corresponding 4 channel amp.
Now that I have a nice enough head unit, that may be feasible (AVH-X4800BS) would this work well?
Now, I need to figure out which 4 channel amp would be better to use, I have Two...
A JL Audio JX400/4D class d, or my Infinity Reference 7540a class a/b
I don’t have a clue which amp would be better suited, cleaner, higher quality...etc, because other then testing...I have no experience with either amp...I know the Infinity is more powerful, but it’s also more then twice the size.
I would also like to ask for some suggestions for high quality pro mid bass drivers, that have tight mid-bass, you can feel, but also in a reasonable price range.
Also suggestions on really nice tweeters.
I’m thinking I’ll either just leave the stock 6x9s on the head unit for rear fill, or just unhook them all together.
Please tell me your thoughts on this.
Tim
Platinum - Posts: 13,725
Posted: August 30, 2019 at 1:33 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Heat is a serious issue with class A/B amplifiers. They are larger only to have enough heat sink to try and dissipate the massive amounts of heat that they produce. Heat is not so much of an issue with class D technology. The JX400 is rated at 75 watts per channel into 4 ohms. It does 100 per channel into 2 ohms.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
