Relay Wiring, LED Lights with Reverse and Dome Light
danny v.
Posted: November 08, 2019 at 5:52 PM / IP Logged Link to Post Post Reply Quote danny v.
Hey guys,
I have a 2018 Chevy Silverado crew cab
I recently installed a rack on my pickup truck.
I have two led pod lights on the rack that I would like to wire into my existing dome light switch, AND to my reverse lights.
-Is this the correct way it should be wired?
-Do I need a fuse from 86 and 87 going to the battery?
-Is a 30 amp relay good?
-Is a 15 amp fuse enough?
Thanks!
Danny V.
Relay Wiring, LED Lights with Reverse and Dome Light -- posted image.
Danny v
eguru
Copper - Posts: 340
Posted: November 09, 2019 at 6:54 AM / IP Logged Link to Post Post Reply Quote eguru
Anytime you connect directly to the battery, the lead should be fused (as close as possible to the battery).
You should be able to find an existing fuse for a non-critical circuit that can be utilized.
