Excalibur RS-370, Adding a Shock Sensor
58vwragtop
Member - Posts: 8
Posted: December 18, 2019 at 4:53 PM / IP Logged Link to Post Post Reply Quote 58vwragtop
I have an Excalibur RS-370 remote start/security system that I am wanting to add a shock sensor to. Is anybody familiar with this system that can tell me how I can add a shock sensor to it?
Im installing it onto an old 1970s car. Just want to be able to use the "pitstop" mode and also have it as an alarm system. I already have some dual shock sensors form previous alarms and didn't know If I could install it on this Excalibur system.
Platinum - Posts: 13,677
Posted: December 19, 2019 at 6:52 PM / IP Logged Link to Post Post Reply Quote i am an idiot
From what I am seeing, that is just a remote start with keyless entry. No security features.
lectricguy
Copper - Posts: 359
Posted: December 21, 2019 at 1:39 PM / IP Logged Link to Post Post Reply Quote lectricguy
The Excalibur RS-x70 series remote starters can only add a shock sensor through the data port, using a special alarm add-on that Omega offers. The Omega Excalibur AU84-TDPB is the correct device to add to your system. It acts as a pass through if you are using a bypass, and has an internal shock sensor as well as alarm inputs for door/trunk. You should be able to find one online.
Good luck, I hope this helps.
Lectric Guy
58vwragtop
Member - Posts: 8
Posted: December 22, 2019 at 8:20 AM / IP Logged Link to Post Post Reply Quote 58vwragtop
That's what I thought, just wasn't totally positive. Thanks!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
