Starter Crank But Not Start, 2015 Lexus GX 460
minhbach
Copper - Posts: 93
Posted: December 30, 2019 at 8:48 PM / IP Logged Link to Post Post Reply Quote minhbach
I have installed the Viper 5704V on the Lexus GX460 2015. The starter sometimes starts Ok but sometimes it just crank and failed to start. And it supposed to tried to start 3 times but it only starts once and if it fails it shut down the remote starts. I currently set as Virtual Tach and I also increased the crank time from .6sec to .8sec. It doing the same thing. Should set to Tach and try to learn the tach signal. This is a D2D connection so I don't have to connect the tach wire.
And can someone help me again with the wiring diagrams and DBALL2 connection for this vehicle. DEI older website can't access anymore. Your help is appreciated.
silvercivicsir
Copper - Posts: 408
Posted: January 02, 2020 at 11:09 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
try learning the data tach from the dball.. start the car normally and press and hold the button on the antenna.. The led will flash when tach is learned.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
