Directed 516L Door Trigger Hookup
xbc4000
Posted: January 26, 2020 at 10:03 AM / IP Logged Link to Post Post Reply Quote xbc4000
Hello
I have a 516L voice module I am installing in a ford flex, the 516L door and trunk wires use (-) the individual flex door trigger wire is (-) and outputs (+) when the door is open, the all door trigger wire is (+) and also outputs (-) when the door is open which I guess is NC ?
I assume I can connect the (-) door trigger wire of the 516L to the (+) all door trigger wire in the flex to give (-) when the door is open ?
As for the trunk wire of the 516L it is also (-) and the flex hatch trigger is (-) which will be (+) when it's open so how would I go about converting the (+) output to (-) to give the 516L (-) when the hatch is opened ?
Would I use a SPTD relay to trigger a (-) when the (+) is activated from opening the door ?
thanks
cpalmer
Copper - Posts: 109
Posted: January 26, 2020 at 10:23 AM / IP Logged Link to Post Post Reply Quote cpalmer
https://www.the12volt.com/relays/relaydiagram8.html
xbc4000
Posted: January 26, 2020 at 10:34 AM / IP Logged Link to Post Post Reply Quote xbc4000
Wouldn't that diagram be the opposite for the hatch ?
when it is open it will give (+) but the 516L will need (-) so positive output to negative output ?
https://www.the12volt.com/relays/relaydiagram9.html
cpalmer
Copper - Posts: 109
Posted: January 26, 2020 at 10:57 AM / IP Logged Link to Post Post Reply Quote cpalmer
Yes the diagram you have in your post should work for that.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
