2004 Lincoln Town Car, Alarm/Remote Start Wiring
stereoguyz
Member - Posts: 13
Posted: March 25, 2020 at 1:08 AM / IP Logged Link to Post Post Reply Quote stereoguyz
Any help would be appreciated
wirewise
Moderator - Posts: 489
Posted: March 25, 2020 at 7:20 AM / IP Logged Link to Post Post Reply Quote wirewise
TOWN CAR     2003-2004
KEY     T-HARNESS     IMMOBILIZER
FDKEY-6     N/A     FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM, Requires Bypass and Extra Ignition Key
PART     COLOR     LOCATION
12 VOLT CONSTANT     YELLOW (+) and LIGHT GREEN/PURPLE (+)     IGNITION SWITCH HARNESS
STARTER     RED/LIGHT BLUE (+)     IGNITION SWITCH HARNESS
STARTER 2     N/A
IGNITION 1     WHITE/YELLOW (+)     IGNITION SWITCH HARNESS
IGNITION 2     PINK/BLACK (+)     IGNITION SWITCH HARNESS
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     GRAY/YELLOW (+)     IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2     BLACK/LIGHT GREEN (+)     IGNITION SWITCH HARNESS
KEYSENSE     N/A
PARKING LIGHTS ( - )     WHITE/BLACK (-)     @ LCM Module, See NOTE *1
PARKING LIGHTS ( + )     BROWN (+)     @ LCM Module, See NOTE *1
POWER LOCK     PINK/YELLOW (TYPE A)     IN DRIVERS DOOR HARNESS
POWER UNLOCK     PINK/LIGHT GREEN (TYPE A)     IN DRIVERS DOOR HARNESS
LOCK MOTOR WIRE     PINK/BLACK (+)     IN DRIVERS DOOR HARNESS
DOOR TRIGGER     BLUE (-) and BLACK/ORANGE (-) Use both, See NOTE *5     @ DRIVERS DOOR Module, See NOTE *3
DOMELIGHT SUPERVISION     BLUE (-) Requires Relay     @ DRIVERS DOOR Module, See NOTE*3
TRUNK RELEASE     RED (5-Wire) See NOTE *2, Requires Relay
SLIDING POWER DOOR     N/A
HORN     DARK BLUE (-)     @ LCM Module, See NOTE *1
TACH     Any wire that is NOT RED or RED/LIGHT GREEN     @ ANY IGNITION COIL or FUEL INJECTOR
WAIT TO START LIGHT     N/A
BRAKE     LIGHT GREEN (+)     @ LCM Module, See NOTE *1
FACTORY ALARM DISARM     LIGHT BLUE/BLACK (-)     @ LCM Module, See NOTE *1
ANTI-THEFT     FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM     TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 the LCM (Lighting Control Module) is located to the RIGHT of the STEERING COLUMN.
NOTE *2 this vehicle uses a 5-wire TRUNK RELEASE SYSTEM, that will require an extra Relay to connect.
NOTE *3 the DRIVERS DOOR Module is located below the mirror in the Drivers door.
NOTE *4 the TACH wire is located at the front of the motor, the coil is on the first spark plug on the drivers side.
NOTE *5 this vehicle has 2 Door trigger wires, when connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE, to connect.
~wirewise~ Verify all wiring with your meter before making any connections!
Thursday, June 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
