1993 Peterbilt 379 Dump Truck, Parking Lights
bat9905
Copper - Posts: 131
Posted: March 25, 2020 at 8:56 PM / IP Logged Link to Post Post Reply Quote bat9905
I have a mid 93 peterbuilt 379 dump truck. Anyone happen to know if parklights need a relay to make light flash stronger off unit? With switch it shows 12 pos which is pretty normal but unlock won’t flash them. APS997e unit too btw
bat9905
Platinum - Posts: 13,670
Posted: March 26, 2020 at 7:02 PM / IP Logged Link to Post Post Reply Quote i am an idiot
That system will handle your parking lights. Where did you connect the White/Red wire? It should be connected to a constant 12 volt source capable of providing 30 amps of current.
bat9905
Copper - Posts: 131
Posted: March 26, 2020 at 10:40 PM / IP Logged Link to Post Post Reply Quote bat9905
I used 12volt off ignition switch. When I metered the white output wire (from alarm) and press lock or unlock it shows 12volt off unit output. The switch at the truck gives the wire I tapped into 12volt. Can’t figure out why if I duplicated what the truck switch does why it wouldn’t work
bat9905
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
