2020 Ford F-350, Door Lock Wiring
celaya4
Posted: May 22, 2020 at 11:21 AM / IP Logged Link to Post Post Reply Quote celaya4
Looked at previous years but can not find the driver door motor lock and unlock wires. Seems like it changed but not sure.
New work truck with a knapheide KUV installed. Trying to wire the back door to lock and unlock with the front doors. Trying to see if there was a tailgate plug but can't find it or the wires to the lock and unlock motors.
Thanks in advance
Celaya
tonanzith
Gold - Posts: 593
Posted: October 01, 2020 at 1:33 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go
2020 Ford F-350 - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Violet/Red (50A)     +     BCM in passenger kick, black 22 pin plug (G), pin 22
Ground     (chassis ground)
Ground 2     Black/Violet     -     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 14
Starter     Blue/White     +     Ignition Switch, black 7 pin plug, pin 7
Ignition     White/Orange     +     Ignition Switch, black 7 pin plug, pin 1
CAN Bus High     White/Blue (HS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 20
CAN Bus Low     White (HS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 19
CAN Bus High 2     Gray/Orange (MS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 23
CAN Bus Low 2     Violet/Orange (MS CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 22
CAN Bus High 3     Green/Orange (HS2 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 18
CAN Bus Low 3     Gray/Blue (HS2 CAN)     Data     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 17
OBD 12 Volts     White/Red (10A)     +     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 13
OBD Ground     Black/Gray     -     Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 1
Power Lock     Gray/Yellow     -     Door Lock Switch in driver door, 4 pin plug, pin 1 or black 8 pin plug, pin 7
Power Unlock     Violet/Gray     -     Door Lock Switch in driver door, 4 pin plug, pin 3 or black 8 pin plug, pin 8
Lock Motor     Gray/Brown     Reverse     Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 35
Driver Unlock Motor     Blue/Green     Reverse     Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 27
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (transponder and ignition)
Parking Lights     Blue/Gray or Blue/Brown (LF/RF); Blue/Gray (LR/RR)     +     BCM in passenger kick, black 22 pin plug (G), pin 3 (LF/RF); 36 pin plug (C), pin 12 (LR/RR)
Parking Lights -     Gray     -     Headlight Switch, black 16 pin plug, pin 11
Note - Parking Lights -: See Tech Doc 1096
Parking Lights Interrupt     Black/Violet     Cut     Headlight Switch, black 16 pin plug, pin 4
Note - Parking Lights Interrupt: See Tech Doc 1096
Hazards     Brown     -     BCM in passenger kick, black 52 pin plug (B), pin 19
Turn Signal (Left)     Blue/Green (LF); Gray/Orange or Gray/Brown (LR)     +     BCM in passenger kick, black 40 pin plug (F), pin 39 (LF); blue 52 pin plug (E), pin 26 or 24 (LR)
Turn Signal (Right)     Yellow/Blue or Yellow/Violet (RF); Green/Orange or Violet/Orange (RR)     +     BCM in passenger kick, black 40 pin plug (F), pin 38 (RF); blue 52 pin plug (E), pin 52 or 23 (RR)
Left Front Door Trigger     Green     - N.C.     Driver Kick --or-- BCM in passenger kick, blue 52 pin plug (E), pin 33
Right Front Door Trigger     White     - N.C.     BCM in passenger kick, blue 52 pin plug (E), pin 21
Left Rear Door Trigger     Green     - N.C.     BCM in passenger kick, blue 52 pin plug (E), pin 46
Right Rear Door Trigger     Yellow     - N.C.     BCM in passenger kick, blue 52 pin plug (E), pin 19
Dome Light     Gray/Violet     +     BCM in passenger kick, 36 pin plug (C), pin 13
Trunk/Hatch Release     Brown/Yellow (tailgate release)     -     Tailgate Release Switch, black 6 pin plug, pin 6 --or-- BCM in passenger kick, blue 52 pin plug (E), pin 14
Trunk Release Motor     Green/White (tailgate release)     Reverse     Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 33
Horn Trigger     Green/White (w/o adaptive steering)     -     Steering Column Module, top of column, white 12 pin plug, pin 1 --or-- BCM in passenger kick, black 52 pin plug (B), pin 18
Horn Trigger 2     Violet/Green (with adaptive steering)     -     Horn Switch-Clock Spring, gray 12 pin plug, pin 5 --or-- BCM in passenger kick, black 52 pin plug (B), pin 18
Memory Seat 1     Violet/White     -     Memory Switch in driver door, black 8 pin plug, pin 5
Memory Seat 2     Yellow     -     Memory Switch in driver door, black 8 pin plug, pin 4
Memory Seat 3     Blue/Orange     -     Memory Switch in driver door, black 8 pin plug, pin 3
Gary Sather
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
