Power Lock Wiring Diagram for 1995 Chevrolet G20 Van
dimitrix
Posted: June 05, 2020 at 4:43 PM / IP Logged Link to Post Post Reply Quote dimitrix
This seems like a long shot but I need the wiring diagram for a 1995 Chevy G20 conversion van -- specifically I need the power lock wires. The power lock on the rear door stopped working. The actuator works when I manually provide a power source, so my guess there's something wrong with the wiring.
Any help is appreciated! Thanks!
wirewise
Moderator - Posts: 489
Posted: June 05, 2020 at 4:47 PM / IP Logged Link to Post Post Reply Quote wirewise
See if this helps: https://www.the12volt.com/installbay/forum_posts.asp?tid=3779
~wirewise~ Verify all wiring with your meter before making any connections!
wirewise
Posted: June 05, 2020 at 4:48 PM / IP Logged Link to Post Post Reply Quote wirewise
https://www.the12volt.com/installbay/forum_posts.asp?tid=96710
dimitrix
Posted: June 05, 2020 at 4:50 PM / IP Logged Link to Post Post Reply Quote dimitrix
Thanks, I already saw these. It doesn't quite answer me where to start troubleshooting my wire problem though.
wirewise
Posted: June 05, 2020 at 4:54 PM / IP Logged Link to Post Post Reply Quote wirewise
There is obviously a break in one or both of the wires going to the rear door actuator. You can tie the two wires from the rear door actuator into the two wires on any other door lock actuator and it should function as it did before.
dimitrix
Posted: June 06, 2020 at 11:03 AM / IP Logged Link to Post Post Reply Quote dimitrix
I found the service manual for my van. According to this wiring diagram the wire should already be shared with the other actuators. Can that be right? https://i.imgur.com/VfmGVRM.jpg
wirewise
Posted: June 06, 2020 at 11:07 AM / IP Logged Link to Post Post Reply Quote wirewise
Yes. As I said before, there is obviously a break in the lead(s) going to the rear door actuator. It could be in the door jamb and may be an easy fix. If not and since you're already in the rear door, simply run two new wires from that actuator to another actuator and call it a day.
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
