2001 Dodge Ram 1500, Clifford AvantGuard 4 Problems
geepherder
Platinum - Posts: 3,668
Posted: October 25, 2020 at 6:05 PM / IP Logged Link to Post Post Reply Quote geepherder
Assuming the manual on this site is the same as yours, there is a green ground-while-armed output (pin 20 on 24-pin harness) you could use to control your own external starter kill relay:
https://www.the12volt.com/installbay/downloads.asp?srch=all&term=clifford+avantguard+4
You could use this relay diagram:
https://www.the12volt.com/relays/relaydiagram10.html
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
