2011 Honda Accord Coupe, Shorted Out Alarm
shadydee2
Member - Posts: 30
Posted: August 20, 2020 at 10:30 PM / IP Logged Link to Post Post Reply Quote shadydee2
ok so now i have a different issue. i need to eliminate the on board amp. can i take the.... or better which wires should i use at the amp to wire straight to the speakers?theres connector A and connector B at the amp. both have speaker connections . connecter a has front left at pins 2 and 14. front right at pins 5 and 17.rear left at pins4 and 16 and rear right at pins7 and 19.connecterB has speaker connections pin 3 rear right negative. pin 4 has rear left negative. pin 12 has rear right positive. pin 13 has rear left positive. pin 15 has front right positive and pin 16 has front left positive.i was going to just unclip and cut and spice or repin the connector for just the speaker wires. theres also speakernetwork control connecters, one for each side of vehicle. passenger side behind the the cd player and drivers side kind by the bluetooth and the drivers side fuse box. where would be best ? or am i way off base here?
daren obrecht
Page of 3
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
