2017 GMC Acadia, Stereo Wiring
merks18
Member - Posts: 21
Posted: September 18, 2020 at 4:22 PM / IP Logged Link to Post Post Reply Quote merks18
Hey fellas, looking for Stereo information on a GMC Acadia. 2017. Thanks in advance.
Platinum - Posts: 13,671
Posted: September 19, 2020 at 9:05 AM / IP Logged Link to Post Post Reply Quote i am an idiot
What are you trying to do?
merks18
Member - Posts: 21
Posted: October 05, 2020 at 4:19 PM / IP Logged Link to Post Post Reply Quote merks18
Looking to add a powered sub to the vehicle.
Posted: October 05, 2020 at 4:27 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Smart key? or limited?
Posted: October 05, 2020 at 4:32 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Limited
Factory Amp Turn-on      (same as power antenna)
Power Antenna      white      +      radio, black 14 pin plug, pin 6
Left Front Speaker (+/-)      tan - gray or tan/black - dk. green      +,-      radio, black 14 pin plug, pins 2 - 9           Notes
Right Front Speaker (+/-)      lt. green - dk. green or lt. green/white - lt. green      +,-      radio, black 14 pin plug, pins 3 - 10           Notes
Left Rear Speaker (+/-)      brown - yellow or brown/white - brown      +,-      radio, black 16 pin plug, pins 5 - 13           Notes
Right Rear Speaker (+/-)      dk. blue - lt. blue or dk. blue - tan      +,-      radio, black 16 pin plug, pins 6 - 14           Notes
Center Channel (+/-)      dk. blue - orange      +,-      radio, brown 16 pin plug, pins 3 - 11           Notes
Subwoofer (+/-)      white - pink      +,-      radio, brown 16 pin plug, pins 4 - 12
On models with amplfier, the subwoofer wires are dk. blue/white - lt. green/black at the amplifier above driver kick, lt. gray 8 pin plug, pins 7 - 3.
I think this vehicle has Active Noise Cancellation. You may want to research that before proceeding.
Posted: October 05, 2020 at 4:35 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Smart Key
Radio Ignition      Violet (retained accessory)      +      Driver Kick, black 76 pin plug, pin 67
Factory Amp Turn-on      Green/Yellow (or MOST Serial Data)      +      Radio behind glove box, gray 20 pin plug, pin 12
Left Front Speaker (+/-)      Blue - Brown/Blue      +,-      Radio behind glove box, brown 20 pin plug, pins 18 - 17
Right Front Speaker (+/-)      Yellow - Yellow/Black      +,-      Radio behind glove box, brown 20 pin plug, pins 16 - 15
Left Rear Speaker (+/-)      Green - Green/Black      +,-      Radio behind glove box, brown 20 pin plug, pins 13 - 14
Right Rear Speaker (+/-)      White - Blue/Black      +,-      Radio behind glove box, brown 20 pin plug, pins 11 - 12
Left Front Speaker - With Amp      Blue - Brown/Blue      +,-      Amplifier under front of center console, green 16 pin plug, pins 5 - 13 (standard) or gray 8 pin plug, pins 3 - 7 (premium)
Right Front Speaker - With Amp      Yellow - Yellow/Black      +,-      Amplifier under front of center console, green 16 pin plug, pins 6 - 14 (standard) or gray 8 pin plug, pins 2 - 6 (premium)
Left Rear Speaker - With Amp      Green - Green/Black      +,-      Amplifier under front of center console, green 16 pin plug, pins 7 - 15 (standard) or black 16 pin plug, pins 7 - 15 (premium)
Right Rear Speaker - With Amp      White - Blue/Black      +,-      Amplifier under front of center console, green 16 pin plug, pins 8 - 16 (standard) or black 16 pin plug, pins 6 - 14 (premium)
Center Channel - With Amp      Yellow/White - Blue/Yellow (premium)      +,-      Amplifier under front of center console, black 16 pin plug, pins 5 - 13
Subwoofer - With Amp      Blue/Gray - Gray/Black (premium)      +,-      Amplifier under front of center console, gray 8 pin plug, pins 1 - 5
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
