2014 Ford E250, Parking Light Wire
trevi18
Posted: November 19, 2020 at 8:20 PM / IP Logged Link to Post Post Reply Quote trevi18
Looking for the parking light wire color for my remote starter the wire I have that I probed when I turn the parking lights on has power I hook the remote starter to it which also shows positive power when remote started but will not turn the parking lights on.
Any help is appreciated
Trevi
wirewise
Moderator - Posts: 489
Posted: November 19, 2020 at 8:26 PM / IP Logged Link to Post Post Reply Quote wirewise
PARKING LIGHTS ( + ) = PURPLE/WHITE (+)     @ DRIVERS KICK PANEL or SJB, GRAY 13-PIN PLUG(E), PIN 6. The SJB (Smart Junction Box) is located under the Drivers Dash.
~wirewise~ Verify all wiring with your meter before making any connections!
trevi18
Posted: November 19, 2020 at 8:52 PM / IP Logged Link to Post Post Reply Quote trevi18
Thank you but it's not working it's a avital 4115l remote starter
Trevi
iskidoo
Silver - Posts: 1,040
Posted: November 19, 2020 at 10:59 PM / IP Logged Link to Post Post Reply Quote iskidoo
Do you have add-on lighting connected to your truck on the same parking light circuit? Is it pulling more than 10 amps total? You may need to use a relay.
Steve G
trevi18
Posted: November 19, 2020 at 11:07 PM / IP Logged Link to Post Post Reply Quote trevi18
No, nothing else connected to the parking circuit, there are 4 wires coming of the back off the headlight switch, could it be a different wire? Everything else on the remote start works with the unlock and lock feature just not the parking lights
Trevi
iskidoo
Posted: November 19, 2020 at 11:31 PM / IP Logged Link to Post Post Reply Quote iskidoo
Its not available at the switch. It's in the 2 locations that wirewise posted above.
Steve G
iskidoo
Posted: November 20, 2020 at 1:01 AM / IP Logged Link to Post Post Reply Quote iskidoo
With a relay you can do it at the switch but it's less work to grab it at the kick or SJB where it can be connected directly.
If you want to use a relay then use this diagram. The 2009 Econoline in the bottom chart should be the correct colors as I believe the wiring is the same from 2009-2016.
DEI Tech Tip 1096
Steve G
