Boa 265B Remote Start Not Starting, 2001 Dodge Ram
blackace13
Member - Posts: 10
Posted: December 03, 2020 at 4:08 PM / IP Logged Link to Post Post Reply Quote blackace13
Still no luck. I switched the two wires as suggested and also tried what you stated above with starting it with key and pressed the start button on the FOB and it didn’t make a difference.
iskidoo
Silver - Posts: 1,040
Posted: December 04, 2020 at 2:45 PM / IP Logged Link to Post Post Reply Quote iskidoo
Perhaps you have a faulty antenna. I’m not sure what you could do other than get another unit and start swapping out parts like the antenna or cable or remote.
Steve G
blackace13
Member - Posts: 10
Posted: December 04, 2020 at 5:43 PM / IP Logged Link to Post Post Reply Quote blackace13
I’ve thought about that too. Was thinking of picking up an Avital unit and just swapping the whole thing. Like I stated before I checked and triple checked everything and all the voltage through out all the wires and everything is good. I’m just stumped as what it could be.
blackace13
Member - Posts: 10
Posted: December 19, 2020 at 2:55 PM / IP Logged Link to Post Post Reply Quote blackace13
I picked up another controller, it’s just the unit itself used. I plugged it in and still no luck. So obviously something is wrong with the wiring set up. I still think I’m having an issue with the factory arm/disarm system seems the only logical issue. Like I posted above all voltage is correct and wiring. Luckily I only spent $5 on the controller. Anyone have any ideas???
