Stereo Has Power, No Sound, 2004 Honda Civic
Platinum - Posts: 13,725
Posted: December 09, 2020 at 7:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
You can do all of the testing I mentioned behind the radio. The instructions I gave are for behind the radio.
geepherder
Platinum - Posts: 3,668
Posted: December 10, 2020 at 3:34 AM / IP Logged Link to Post Post Reply Quote geepherder
If those are the original speakers, it wouldn't be uncommon for them all to be blown.
dj smith
Member - Posts: 7
Posted: December 10, 2020 at 11:53 AM / IP Logged Link to Post Post Reply Quote dj smith
all of them ill look for replacement speakers test it I dread removing the door panels
Donald Smith
dj smith
Member - Posts: 7
Posted: December 10, 2020 at 1:32 PM / IP Logged Link to Post Post Reply Quote dj smith
I removed the front door speakers will I get a reading with a multimeter if I connect th eleads to the speaker
Donald Smith
geepherder
Posted: December 10, 2020 at 4:07 PM / IP Logged Link to Post Post Reply Quote geepherder
No need to pull any door panels just to test them. Test each pair of speaker leads behind the stereo, unplug stereo and test there. The white pair is left front, grey is right front, green is left rear, purple right rear. Even if you get a reading, you can try "popping" the speakers with a battery:
https://www.the12volt.com/installbay/forum_posts.asp?tid=74637
Posted: December 10, 2020 at 8:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Do not pull the door panel. Checking all this behind the radio will check everything that needs to be checked. Pulling the panel and checking the speaker will only tell you if the speaker is ok. It will not check the wiring between the radio and speaker. Somebody let me know if you are able to read this. I am beginning to believe I clicked the invisible icon.
geepherder
Posted: December 11, 2020 at 12:35 AM / IP Logged Link to Post Post Reply Quote geepherder
Maybe change your handle to "I am invisible".
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
