VSS Signal Splitter to Speedometer and ECM
jaytan1976
Posted: December 23, 2020 at 1:37 AM / IP Logged Link to Post Post Reply Quote jaytan1976
what do you use to split the vss signal to the speedo gauge and ecm?
currently, i'm getting CEL vss error code 17 on my 1994 honda prelude si
i had to recently replaced the speedo and tacho, tapping the signal from the ecm to the gauges. i've put in voltage regulators and capacitors to clean up the signal to the electrical gauges. all works well but the voltage regulators and capacitors are 'stealing' the signal away from the ecm, tripping the error code.
jaytan1976
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
