2015 Toyota Tacoma, Stellar STRS9960 Alarm/Remote Start
vorhes12
Posted: January 11, 2021 at 3:55 PM / IP Logged Link to Post Post Reply Quote vorhes12
Hello everyone,
I have a 2015 toyota tacoma trd, 4 door and I just bought a stellar strs9960 alarm with remote start to install in it. I didn't see the wiring information for this vehicle in the threads. Can someone please send me the information or a link to access it? Also, does someone know which type of central door locking system this vehicle has. It seems that toyota uses a negative trigger door locking system, but I want to make sure that this hasn't changed with years or vehicles.
Also, I need some help with a few other issues I'm not understanding with the instructions that were sent with the system. The first is the system diagram shows a start sensing connection that I need to make. It looks like I need to wrap a wire around the high voltage igniter with the picture showing what appears to be a wire going to a coil. I'm unsure what I'm supposed to connect to. Can I just tap into the igniter circuit wire?
2015 Toyota Tacoma, Stellar STRS9960 Alarm/Remote Start - Last Post -- posted image.
Another question I have is about the engine cut off circuit. I'm not sure which relay the connection is supposed to be made to and how the connection is supposed to be made.
Any help is greatly appreciated, Thank you!!
vorhes12
Posted: January 11, 2021 at 3:56 PM / IP Logged Link to Post Post Reply Quote vorhes12
Sorry guys, this tacoma is has a G key
wirewise
Moderator - Posts: 489
Posted: January 11, 2021 at 3:59 PM / IP Logged Link to Post Post Reply Quote wirewise
TACOMA     2009-2016
KEY     T-HARNESS     IMMOBILIZER
N/A     N/A     TOYOTA'S TRANSPONDER SYSTEM, See NOTE #1
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     WHITE/RED (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 5
STARTER     GREEN/BLACK (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 7
STARTER 2     BLACK/WHITE (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 3
IGNITION 1     BLACK/RED (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 6
IGNITION 2     BLUE/YELLOW (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 1
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     WHITE/GREEN (+)     @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 2
ACCESSORY/HEATER BLOWER 2     N/A
KEYSENSE     N/A
PARKING LIGHTS ( - )     GREEN (-)     @ HEADLIGHT SWITCH, (WHITE, 20-Pin Plug) Pin 18
PARKING LIGHTS ( + )     GREEN (+)     @ DASH FUSE BOX, (WHITE, 13-Pin Plug(D) Pin 10
POWER LOCK     BLUE/WHITE (TYPE B)     in DRIVERS KICK PANEL, (WHITE, 10-Pin Plug) Pin 6
POWER UNLOCK     GRAY (TYPE B)     in DRIVERS KICK PANEL, (WHITE, 10-Pin Plug) Pin 7
LOCK MOTOR WIRE     BLUE/RED (5-wire type)     in DRIVERS KICK PANEL, (WHITE, 12-Pin Plug) Pin 10 or (WHITE, 6-Pin Plug) Pin 4
DOOR TRIGGER     GREEN/YELLOW (-)     @ DASH FUSE BOX, (WHITE, 18-Pin Plug(F) Pin 7
DOMELIGHT SUPERVISION     BLUE (-)     @ DASH FUSE BOX, (BLACK, 13-Pin Plug(E) Pin 9
TRUNK RELEASE     N/A
SLIDING POWER DOOR     N/A
HORN     GREEN/RED (-)     @ DASH FUSE BOX, (WHITE, 18-Pin Plug(C) Pin 10
TACH     BLACK/WHITE (AC)     @ DATA LINK Connector, (WHITE, 16-Pin Plug) Pin 9
WAIT TO START LIGHT     N/A
BRAKE     BLUE (+)     @ DASH FUSE BOX, (WHITE, 13-Pin Plug(D) Pin 13
FACTORY ALARM DISARM     GREEN/BLACK (-) NOTE #2     in DRIVERS KICK PANEL, (WHITE, 10-Pin Plug) Pin 8
ANTI-THEFT     TOYOTA'S TRANSPONDER SYSTEM, See NOTE #1     @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: TOYOTA'S TRANSPONDER SYSTEM, Requires Bypass Module: (for Remote Start Only) USE, A 791 bypass and a spare key or an INTERFACE MODULE (no spare key needed) Part # PK-ALL.
NOTE #2: TEST this wire while turning the Key in the Drivers Door, this wire will also Unlock the Doors WITH A DOUBLE PULSE.
~wirewise~ Verify all wiring with your meter before making any connections!
vorhes12
Posted: January 11, 2021 at 4:36 PM / IP Logged Link to Post Post Reply Quote vorhes12
Thank you!!
wirewise
Posted: January 11, 2021 at 4:44 PM / IP Logged Link to Post Post Reply Quote wirewise
More info: https://www.the12volt.com/installbay/forum_posts.asp?tid=137166#696509
vorhes12
Posted: January 11, 2021 at 4:50 PM / IP Logged Link to Post Post Reply Quote vorhes12
I saw the 2014 but I wasn't sure that was applicable to my year. I did find some images from pages of the service manual, but they said 2015-2018 toyota tacoma and I thought I had to find diagrams from those specifically.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
