2006 Toyota Aygo, Alarm/Remote Start Wiring
roakusfm
Copper - Posts: 71
Posted: June 19, 2021 at 3:45 PM / IP Logged Link to Post Post Reply Quote roakusfm
Hello friends,
Good evening to you all, Can someone help me to get wiring diagram for Toyota Aygo 2006 to complete my remote start? Now I am looking for Lock and unlock wire. Thanks in Advance
Peace and Love
geepherder
Platinum - Posts: 3,668
Posted: June 20, 2021 at 6:43 AM / IP Logged Link to Post Post Reply Quote geepherder
That platform is not sold in the states. If you have power door lock switches, you can test the wires there. If not, check for wires that run to the door lock cylinder in the driver's door and test them
mgoetz74
Silver - Posts: 424
Posted: June 21, 2021 at 3:28 PM / IP Logged Link to Post Post Reply Quote mgoetz74
Starter     black     +     loom to column
Ignition     black/white     +     loom to column
Note - Ignition: FUEL- BLACK/GREY REF DRIVERS KICK LOOM TO REAR
Power Lock     orange     5wi     see note
Note - Power Lock: WHITE 10WAY CONNECTOR FOUND IN DRIVERS KICK
Power Unlock     lt blue     5wi     see note
Note - Power Unlock: WHITE 10WAY CONNECTOR FOUND IN DRIVERS KICK
Turn Signal (Left)     orange     +     see note
Note - Turn Signal (Left): BLUE 12WAY CONNECTOR BEHIND CLOCKS
Turn Signal (Right)     white     +     see note
Note - Turn Signal (Right): BLUE 12WAY CONNECTOR BEHIND CLOCKS
Left Front Door Trigger     pink     -     drivers kick
Left Front Window (Up/Down)     red
Right Front Window (Up/Down)     red
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
