2012 Toyota Prius, PTS, CM900-AS, Blade-AL
qpham504
Copper - Posts: 51
Posted: July 27, 2021 at 2:38 PM / IP Logged Link to Post Post Reply Quote qpham504
I have a cm900-as with the blade-al. I'm needing some help figuring out the remote start part on the PTS function. I'm assuming I'll need a relay system but just don't know what wires to tap into since, from the diagrams that were posted for me prior, there is no ignition and starter wire. Any help is appreciated. First time working on a PTS system, I'm more familiar with Compustar systems.
mgoetz74
Silver - Posts: 424
Posted: July 28, 2021 at 9:41 AM / IP Logged Link to Post Post Reply Quote mgoetz74
just follow the sheet like it says, there are no extra starts or ignitions to hook up. Its all done by the bcm on the can bus wires
https://images.idatalink.com/corporate/Content/Manuals/DL-TL2/BLADE-AL(DL)-TL2-EN_20201119.pdf
"WARNING:
DO NOT CONNECT ANY OTHER
ACCESSORY,IGNITION OR START WIRE
FROM THE REMOTE STARTER TO THE
VEHICLE. THE INTERFACE MODULE
IS HANDLING THE REQUIRED VEHICLE
POWER AND START SEQUENCE FROM
THE PUSH TO START BUTTON CIRCUIT"
silvercivicsir
Copper - Posts: 408
Posted: July 28, 2021 at 1:06 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
also don't be surprised, when you remote the car, and the engine doesn't turn on. As long as the "ready" or green car light comes on, its running. The engine only turns on when it needs to. If you crank the heater, the engine will fire up within a few seconds.
Also if you follow the diagram on idata, it's assumed you know Ground (blk) from the rs brain is a mandatory connection.
qpham504
Copper - Posts: 51
Posted: July 28, 2021 at 2:13 PM / IP Logged Link to Post Post Reply Quote qpham504
lol, yeah when I 1st pressed the PTS button the engine didn't run. 1st ever Hybrid for me and alarm install on one. Good experience under the belt.
qpham504
Copper - Posts: 51
Posted: August 05, 2021 at 5:59 PM / IP Logged Link to Post Post Reply Quote qpham504
Ok. Alarm is wired in like the instructions state. I can control the alarm with the factory and non-factory remotes. My problem is that I can't get the remote start to work. I only have what the blade required wired in. Am I missing anything here?
qpham504
Copper - Posts: 51
Posted: August 05, 2021 at 6:20 PM / IP Logged Link to Post Post Reply Quote qpham504
More details, I disabled the cranking, no tach. What it does when I enable remote start is just as if I only pressed the PTS button once.
silvercivicsir
Copper - Posts: 408
Posted: August 06, 2021 at 12:35 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
if the green car light or "ready" is on when you remote start it, it's working fine.. like i said the engine only turns on when it needs to, so try cranking the heater fan to high, and the engine should start in a few seconds.
qpham504
Copper - Posts: 51
Posted: August 06, 2021 at 12:40 AM / IP Logged Link to Post Post Reply Quote qpham504
Hey,
No it's not doing that. So you know how when you first get in the car and just hit the PTS button and part of the cluster lights up (well just a few lights). This is what its doing, the cluster lcd isn't coming on. Only like the CEL and another red icon. I think I do need to hook up that 2nd ignition wire.
mgoetz74
Silver - Posts: 424
Posted: August 06, 2021 at 12:06 PM / IP Logged Link to Post Post Reply Quote mgoetz74
AGAIN........
"WARNING:
sounds like something else is wrong. I've done hundreds of these and followed the manual with no problems. did you learn the tach wire, make sure you are going by pin location and not just grabbing any wire color it lists
qpham504
Copper - Posts: 51
Posted: August 06, 2021 at 12:48 PM / IP Logged Link to Post Post Reply Quote qpham504
directed doesn't provide a tach wire location. All connections were made to pin location, not by color wire. I've tested all door triggers and hatch, tested ignition as well. I followed the diagram I requested here.
https://www.the12volt.com/installbay/forum_posts.asp?tid=144302
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
