2016 Honda Vezel Hybrid, GPS Install
kevin_1
Member - Posts: 9
Posted: September 25, 2021 at 5:49 PM / IP Logged Link to Post Post Reply Quote kevin_1
Gooday, anyone knows which part to tap into for the remote cut off for a gps install for a Honda vezel hybrid 2016. The ignition is push to start.
Platinum - Posts: 13,667
Posted: September 26, 2021 at 8:08 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Wiki says this is the same as the HR-V on this side of the pond. They do not make a hybrid. We have no wiring info available for this vehicle.
kevin_1
Member - Posts: 9
Posted: September 26, 2021 at 9:10 PM / IP Logged Link to Post Post Reply Quote kevin_1
yes its also called an hr-v. And Yes there's a hybrid to it
Posted: September 27, 2021 at 9:07 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Starter      Green      +      Keyless Access Control Unit behind instrument cluster, gray 36 pin plug, pin 32      Directwire
Above is the info for non hybrid with smart key. If you find such wire, use a meter to verify.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
