Astroflex BBW, Unable to Program Remotes
jacobusm
Posted: November 19, 2021 at 3:00 PM / IP Logged Link to Post Post Reply Quote jacobusm
I have a 2008 Honda Ridgeline .It has a AstroStart Astroflex BBW Item 392-127-317 Rev.1 remote starter. I recently discovered that the wire for the antenna was cut when they replaced the windscreen months ago. I bought a new antenna, wire and remote. I tried to program the remotes but it's not working. I get the four flashes from the parklights but nothing happens when I press the lock or start button on the remote. Is there a way to find out if the brain is not working because I can hear the clicking when I start the programming. The LED on the module blinks when the brake pedal is pushed. The LED flashes when the engine is running. The switch is ON. New battery in the remote. I would really appreciate any help or info to get the remote starter to work since I don't have the money to install a new remote starter. I took pictures of the setup if need be.
jacobusm
Posted: November 19, 2021 at 4:51 PM / IP Logged Link to Post Post Reply Quote jacobusm
Forgot to mention. It's a regular key start. And the remotes are 2205A and 4204A.
silvercivicsir
Copper - Posts: 406
Posted: November 22, 2021 at 1:38 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
have you tried, flip dip switch 8 to on, and then press the brakes.. then press lock on each remote, then flip 8 to off, and then press the brakes.
jacobusm
Posted: November 22, 2021 at 8:32 PM / IP Logged Link to Post Post Reply Quote jacobusm
Yes but unfortunately that also didn't work. I want to know if the brain got fried when the cut the wire of the antenna. I was hoping there was a way to test if the brain or module is damaged. Thanks
silvercivicsir
Copper - Posts: 406
Posted: November 23, 2021 at 7:45 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
when you do the flip 8, brake and then press lock of the remotes, the led on the brain should flash.. if it doesn't I would suspect a shorted antenna port.
jacobusm
Posted: November 25, 2021 at 7:57 PM / IP Logged Link to Post Post Reply Quote jacobusm
Thanks guys I got it working! Appreciate all your help
lmpederson
Posted: August 21, 2023 at 1:10 PM / IP Logged Link to Post Post Reply Quote lmpederson
Hi ... I have the exact same unit with missing remote. Can you tell me how you were ever able to find a remote. Desperate. lylepederson@sasktel.net
old car guy
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
