2019 Nissan Frontier, Alarm/Remote Start Wiring
caraudioholic24
Member - Posts: 37
Posted: December 16, 2021 at 4:58 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good Morning, I am in need of wiring info for the 2019 Nissan Frontier. Any help is greatly appreciated. Have a blessed day!
Platinum - Posts: 13,672
Posted: December 16, 2021 at 7:37 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The entire vehicle?
caraudioholic24
Member - Posts: 37
Posted: December 16, 2021 at 8:23 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Sorry.. Doing a remote start keyless entry and alarm. Directech sheet would awesome. Thank You
Posted: December 16, 2021 at 8:52 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      green (40A)      +      ignition switch, white 6 pin plug, pin 3 --or-- driver kick, white 6 pin plug, pin 4      Directwire
Ground      (chassis ground)
Starter      gray      +      ignition switch, white 6 pin plug, pin 2 --or-- driver kick, white 6 pin plug, pin 3      Directwire
Second Starter      lt. green (should not be required for remote start)      +      ignition switch, white 6 pin plug, pin 6      Directwire
Ignition      white/green      +      ignition switch, white 6 pin plug, pin 1 --or-- driver kick, white 6 pin plug, pin 2      Directwire
Accessory      red      +      ignition switch, white 6 pin plug, pin 4 --or-- driver kick, white 6 pin plug, pin 5      Directwire
Second Accessory      green/yellow      +      ignition switch, white 6 pin plug, pin 5 --or-- driver kick, white 6 pin plug, pin 1      Directwire
Keysense      black      +      key switch, white 2 pin plug, pin 1      Directwire
CAN Bus High      blue      data      data link connector, white 16 pin plug, pin 6
CAN Bus Low      pink      data      data link connector, white 16 pin plug, pin 14
CAN Bus High 2      blue      data      BCM right of steering column, white 40 pin plug, pin 39      Directwire
CAN Bus Low 2      pink      data      BCM right of steering column, white 40 pin plug, pin 40      Directwire
IMMO Data      brown      data      NATS Antenna Amp on ignition switch, white 4 pin plug, pin 4      Directwire
IMMO Data 2      brown      data      BCM right of steering column, white 40 pin plug, pin 25
IMMO Clock      gray      data      NATS Antenna Amp on ignition switch, white 4 pin plug, pin 2      Directwire
IMMO Clock 2      gray      data      BCM right of steering column, white 40 pin plug, pin 21
Security Light      green      -      BCM right of steering column, white 40 pin plug, pin 23
Power Lock      violet      -      driver kick or BCM right of steering column, white 15 pin plug, pin 5      Directwire
Power Unlock      lt. green      -      driver kick or BCM right of steering column, white 15 pin plug, pin 6      Directwire
Lock Motor      violet      5 wire      driver kick or BCM right of steering column, black 15 pin plug, pin 10      Directwire
Driver Unlock Motor      gray      5 wire      driver kick or BCM right of steering column, black 15 pin plug, pin 4      Directwire
Passenger Unlock Motor      blue      5 wire      BCM right of steering column, black 15 pin plug, pin 11      Directwire
Factory Alarm Arm      lt. blue (driver door key lock)      -      BCM right of steering column, white 40 pin plug, pin 8 --or-- driver kick      Directwire
Factory Alarm Disarm      gray (driver door key unlock)      double -      BCM right of steering column, white 40 pin plug, pin 7 --or-- driver kick      Directwire
Disarm No Unlock      (see factory alarm disarm)
Parking Lights      red      +      electric brake pre-wiring near ign switch, white 6 pin plug, pin 4      Directwire
Hazards      green      -      BCM right of steering column, white 40 pin plug, pin 29      Directwire
Turn Signal (Left)      lt. green      +      BCM right of steering column, black 15 pin plug, pin 5      Directwire
Turn Signal (Right)      green      +      BCM right of steering column, black 15 pin plug, pin 6      Directwire
Headlight      pink (L); red (R)      +      headlights or underhood fuse box, brown 8 pin plug, pins 4, 6
AutoLights      gray      -      BCM right of strng column, wht 40 pin plug, pin 33      Directwire
Reverse Light      lt. blue      +      pass side engine compartment, chassis harness to rear
Left Front Door Trigger      gray      -      BCM right of steering column, white 15 pin plug, pin 7      Directwire
Right Front Door Trigger      lt. green      -      BCM right of strng column, wht 40 pin plug, pin 12      Directwire
Left Rear Door Trigger      pink      -      BCM right of strng column, wht 15 pin plug, pin 8      Directwire
Right Rear Door Trigger      blue      -      BCM right of strng column, wht 40 pin plug, pin 13      Directwire
Dome Light      brown      -      BCM right of steering column, black 15 pin plug, pin 8      Directwire      Notes
Tachometer      NOT white/green      ac      any fuel injector
Neutral Safety      beige (M/T)      -      Engine Cntrl Mod on pass fender, bk (I4) or gy (V6) 32 pin plug, pin 3
Clutch Pedal      red or blue      +      clutch switch, blue 2 pin plug, pin 2      Directwire
Fuel Pump      red      +      underhood fuse box, white 16 pin plug, pin 11
Rear Defroster      yellow      -      BCM right of steering column, white 15 pin plug, pin 1
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      gray      5 wire      left front heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat      white      5 wire      right front heated seat switch, brown 6 pin plug, pin 5
Speed Sense      lt. blue (except base audio)      8-Pulse      radio, white 20 pin plug, pin 18           Notes
Brake Wire      yellow or lt. green      +      brk sw or electric brk pre-wire near ignition sw, white 6 pin plug, pin 2      Directwire
Parking Brake      green      -      parking brake switch or driver kick, harness to rear      Directwire
Horn Trigger      red      -      driver kick, white 16 pin plug, pin 9      Directwire
Horn Trigger 2      red (alternate location)      -      horn switch-clock spring, gray 8 pin plug, pin 7
Wipers      gray (LO); blue (HI)      +      wiper motor or underhood fuse box, brown 12 pin plug, pins 8, 11
Left Front Window (Up/Down)      green/red - green/white      A      power window main switch, white 16 pin plug, pins 6 - 7
Right Front Window (Up/Down)      pink - lt. blue      A      driver kick, brown 12 pin plug, pins 6 - 1
Left Rear Window (Up/Down)      red - lt. green      A      driver kick, brown 12 pin plug, pins 11 - 12
Right Rear Window (Up/Down)      yellow - pink      A      driver kick, brown 12 pin plug, pins 5 - 4
Sun Roof (Open/Close)      red - lt. blue (function with ignition on only)      -      sunroof switch, white 3 pin plug, pins 1 - 3
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
